Author Subject: Rear beam tube end (bearing housing) O/S
cornish_pug
Does anybody have a good rear beam tube end for holding the outer bearing.
Can you buy them from Peugeot?
Thanks
Team Diesel
Posted 25th Nov 2011 at 13:12
jord294
There is no end. You need another tube
Posted 25th Nov 2011 at 13:29
jord294
I'm pretty sure it would of been cheaper to buy a re-furbed one from me in the first place
Posted 25th Nov 2011 at 14:06
LOL
you need another crossmember, get down't scrappy and strip a few apart see if they have a good one.
Posted 25th Nov 2011 at 14:59
cornish_pug
The tube end was worn but not majorly. I managed to pack the the worn side with some decent shim.
Team Diesel
Posted 25th Nov 2011 at 16:42
Rich E Forum Admin
Eesh. I'll give you about 2000 miles before you're taking it apart again then.
Posted 25th Nov 2011 at 16:44
I would have at least built it back up with a decent weld and turn it back down.
Posted 25th Nov 2011 at 17:08
