Author Subject: Oil Level Gauge Q
iplay
On startup. key in 2nd position. oil gauge shows the oil level.
The problem is it randomly shows different levels. Sometimes on the white mark just before the red and other times half way. It used to just sit on the white mark near the red. The oil is correctly topped up and the car is driven each day.
Posted 30th Nov 2011 at 09:28
nothing out of the ordinary I'm afraid, not unknown for the wiring to be damaged though.
Posted 30th Nov 2011 at 10:10
russbez
mine does this sometimes, i just thought it was dodgy earth or some sort of sensor on its way out
done it about 2 month ago, hasnt done it recently
dont we mean "oil temperature gauge"?
My Rallye project thread
Posted 30th Nov 2011 at 10:52
probably does if its a phase 2 Smile
Posted 30th Nov 2011 at 11:06
iplay
yesish .. oil level gauge ... *edited* Thumbs up
Posted 1st Dec 2011 at 11:02
iplay
the sensor moves everytime so i don't think the wiring is damaged.
where is the sensor located and how does it work?
Posted 1st Dec 2011 at 11:06
monkeyman
The sensor seems very sensitive, where I normally park is good and flat, but anywhere with a bit of camber and I get low readings.
Forum Search Clicky
Posted 1st Dec 2011 at 11:29
on these engines its in the front of the block pointing down into the sump, unsure on exactly how it works though.
Posted 1st Dec 2011 at 11:53
