Author Subject: Trailing arm shaft depth
cornish_pug
How far should the trailing arm shafts be pressed into the trailing arm.
Team Diesel
Posted 8th Dec 2011 at 17:51
jord294
you still doing this?
i tend to leave approx 1-2mm so the foam ring on the arb end plate has somewhere to sit in
Posted 8th Dec 2011 at 17:58
recessed 2mm from the outer face, pug specified this.
Posted 8th Dec 2011 at 18:00
cornish_pug
Unfortunately yes!
Only been able to do bits here and there, been busy with work.
Cheers for the info guys!
Smile
Team Diesel
Posted 8th Dec 2011 at 18:20
