Post #46
CUJ wrote:Clicky - even surprised myself with that show of memory..
Well done for remembering Jon!
24seven wrote:
You have to beat them with an angry stick to make them quick. They don't hang about, but unless you're really pulling the tits off of them they feel a bit wheezy.
If you look at the torque levels you probably won't be impressed, and explains that view ^ that many share. The figure isn't far off the Rallye actually
Indeed you do have to drive them hard to get the best out of them. Which is perfect, for me at least, it can be a lazy cruiser when you want it to be, but it can also shift when you want it to
. You have the advantage of a big rev range to play with. On that note, its quite an involving car to drive, critics would argue it requires 'too much effort' to 'wind the car up' and hit the higher revs all the time but for me that's part of the fun of driving a NA car
gman wrote:One thing I felt in the S2000, is the anal twitching that went on everything I accelerated going round a bend. I'm sure I would get used to it with time, but not having any decent RWD experience, it can be pretty unnerving!
Big time! I've had the back end out on a few occasions when I did not expect it. Have to be real careful in greasy conditions, and just remember not to drive it like a FWD! The fact that torque levels weren't massive didn't bother me because the S2000 served as a great, gradual introduction to the world of RWD for me - power available when I open the taps an hit VTEC, reserved behaviour otherwise.
roland rat wrote:The S2K is a fantastic car but need to be looked after to get the best from them.The rear suspension bushes are prone to seizeing and are a costly repair if not looked after.other than that they seemed pretty sold when i wanted one before i bought my house
Yup, bushes is one of the biggest common problems. Not cheap to address if they're all seized up.
gman wrote:
Cheers Ash, I'm aware of the seized bushes problems on these cars, which can be a real pain given that they are so sensitive to geometry changes. Trouble is, unless you want to pay to get the geometry checked, there is no way of knowing if they are seized before buying the car.
You can, I went to BlackBoots aka Wheels In Motion to get mine checked. I informed the garage I purchased the car from that for any adjustments required on the bushes/geo, they'd be getting the bill. In the end, all bushes were fine, geo was within factory margins and the bill came to less than £120. But I was lucky enough to have picked up a one-owner car which had been serviced all its life at Chiswick Honda with no expense spared. There are some real dogs out there too, typically anything under £7k and it'd need work to get into good shape.
gman wrote:The earlier ones had a more pronounced vtec kick, but after 2004, they are more refined.
Honda cheated a bit with earlier model years, i.e. pre-04, by leaning out the mixture just before VTEC; this made it seem like the car made noticeably more power over 6k RPM. Not sure I'd like a 'jerk' on cutover anyway... mines on a 04 plate
___=[ 306 RALLYE ]=__
Rallye Pics///R.I.P: T499 HFC///Farewell: T153 JCP <==
==> Welcome: S2000
