Author Subject: Rains getting in!
Batesy86
After the heavy rain, I've found damp patches on the roof lining at the top of the b pillar. Also the os rear footwell is damp Sad where does it usually come from and how can it be stopped? It's a sunroof model.
Posted 19th Dec 2011 at 12:59
Park it in a garage.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 19th Dec 2011 at 13:00
Also check your gutters for the sunroof arent blokes
Posted 19th Dec 2011 at 13:01
LOL blocked
Posted 19th Dec 2011 at 13:02
atterz
Gutters in sunroof, my DT does it after sitting under a tree for 9 months! Get a long piece of stiff wire and poke it through. Then test with a cup of water. Best to sort it quick or risk a rotten roof!
owain wrote:
Posted 19th Dec 2011 at 13:04
sixygti2
Here
Not sure how you stop it though, sorry
LOL
Still watching you...
Posted 19th Dec 2011 at 13:08
Batesy86
How do you get to these gutters? Won't have a garage to keep it in until late January!
Posted 19th Dec 2011 at 13:19
also check door seals for any small tears/rips in them
Posted 19th Dec 2011 at 13:31
atterz
open the sunroof and in the front corners you will see the gutters/expelling water thingy majigs (this name confirmed on servicebox), these are the things you must clean out, and the lead to just behind the front wings.
Posted 19th Dec 2011 at 13:33
Batesy86
I'll arm myself with a metal coat hanger and take a peek this afternoon
Posted 19th Dec 2011 at 13:47
mechanical_repairs
Also re seal the aerial base, very common.
Carl
Posted 19th Dec 2011 at 14:11
Forgot about the ariel, I had to seal mine.
Posted 19th Dec 2011 at 14:14
Batesy86
Carl
Would this cause the rear well behind the drivers seat the get wet though?
Just been outside, my coat hanger wouldn't go down the holes, presumably its to thick and doesn't have enough give to turn corners. I poured 1/2 pint of water down each one though and water was exiting under the car at a decent rate.
Did find a small tear in the door seal though, I can;t see how it would explain a very damp carpet at the back though...The seal doesn't look like it fits well, it seems an inch too short so isn't tight around the whole door, one place will always be lifting away. Here's a pic of the tear.
Posted 19th Dec 2011 at 14:34
Batesy86
Here's a pic of the seal coming away. It wants to come away at some point no matter where!
Posted 20th Dec 2011 at 11:56
with a tear like that it wont be helping at all, find a replacement Thumbs up
Posted 20th Dec 2011 at 12:19
jimmyhackers
like has been said before. its either your aerial seal or sunroof seal. check their condition and replace if needed. i cleaned then greased up my seals on my 1.4 roof, that helped and was free/easy to do
that door seal tear may be letting in some water. but i wouldnt think enough to get to the roof. are the carpets wet around the bottom of the door seal? if so it may need replacing
i know you said this happened after heavy rain so its more that likely the seals but the other possibility is your rear washer line is leaking? i think it runs on that side. have you been using your rear washer jet? does the water inside smell or have any discolour to it? has your washer bottle been emptying quickly?
good luck with fixing it
Posted 20th Dec 2011 at 12:26
mcfc1987
leaks normally stop if you pay your £5 membership Thumbs up
Posted 20th Dec 2011 at 12:31
atterz
Tryed that and the DT sunroof still leaks Sad.
Posted 20th Dec 2011 at 12:48
Batesy86
Lol! Maybe after xmas!
I'll have to check the sunroof seal then as the drains are working. Can you still get seals at such from Peugeot?
Posted 20th Dec 2011 at 14:22
seans6
I used vasaline on my old spaxo sunroof when it leaked, was a temp fix before i got a new seal and worked a treat! Just make sure no ones looking when your rubbing vasaline into the roof LOL Ninja
Posted 20th Dec 2011 at 15:45
pugzy
Exactly same happened on my 106 mate...
Pulled back the roof lining above the drivers side to see the underside of the sunroof corner - it was totally rusted and where the drain pipes beginning at the sunroof and ending up down towards the drivers foot well was blocked. The water gathered in the corner of the sunroof, rusted and rotted through the bodywork, straight onto the lining. This soaked the lining and down the A-pillar, into the footwells on the drivers front and rear sides.
£60 later at the bodyshop where it was resealed and rebuilt and I've had no problems since Thumbs up
Pugzy...aka Mike Thumbs up
Ex-Platinum silver 306 GTi6 owner...now an Ex-Scarlet Red 406 3ltr V6 Coupe owner too Sad
Now driving a China Blue 106 1.5 Diesel..."The Money-Saving and Debt-Busting Machine" LOL
Posted 21st Dec 2011 at 00:35
mark.evs
That damp patch will be where the rubber pipe meets the metal work of the sunroof, get under the roof linging and stick a jubile clip on it. I done it on my old dt too.
My GTi6 track project
White Rallye project
Posted 21st Dec 2011 at 15:56
Batesy86
IS there an easy way of getting under other than taking off the a/b/c pillar trims off?
Posted 21st Dec 2011 at 21:02
