displaying posts 26 to 50 of 488
Pages (20): 1 [2] 3 .. last
Author Subject: GETTING THERE Fatlapits turbo (turbo frog)
fatlapit
f*ck it al chuck it lol
Posted 20th Feb 2012 at 22:52
fatlapit
did a bit more today manifold should be finished tomorrow Smile
turbo needs a bit reangling
how it sits in the engine bay
Other thing that are happening atm, dash out to remove a/c and change the matrix, also in two minds whether to flock it and also need to make a feature of the ecu which is gonna sit where the pass. airbag used to be.
Posted 24th Feb 2012 at 23:16
fatlapit
new intercooler
Posted 29th Feb 2012 at 20:55
swiftyboi006
Nice start to what could be a beast of a car. I think it was binka who is/was the turbo man to talk to if you need any advice Thumbs up
Black p3 Love
Posted 29th Feb 2012 at 21:39
fatlapit
cheers mate for that Smile
Posted 29th Feb 2012 at 21:53
JWP EFi
Turbo Legend!
hmmm, evening welding courses on the cards!!!
selling my 405 T16 manifold to help towards a DP setup
Posted 29th Feb 2012 at 22:58
fatlapit
Just tacs it shud be getting welded up this w/e and making the down pipe. also making a metal thermostat housing. will get pics of the bottom mount. mate i have saved £800 making it myself.
Posted 29th Feb 2012 at 23:02
JWP EFi
Turbo Legend!
be interesting to see how it works out! fancy making another one lolBig grin
Posted 29th Feb 2012 at 23:28
fatlapit
Could do mate if the price is right Smile
Posted 1st Mar 2012 at 07:04
fatlapit
Post #35
intercooler mock up
in the hole
bumper on
loads of room
plans for the oil cooler is to put it where the horns sit or try and fit it inbetween the rad and cooler.
Posted 2nd Mar 2012 at 21:06
playboyb
Post #36
Can't wait to see how this turns out, will be keeping an eye on this one! Good progress pal!
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 2nd Mar 2012 at 21:14
fatlapit
Post #37
did a bit more today, just got in fact!!
manifold is near completion
also thought i would bin that horrible piece of plastic that feeds the thermostat
heres what i started with
couple of hours later
finished
sorry but forgot to get a pic of the bottom mount, also didn`t have time to start the downpipe as i had to help a mate out on his maxi 5 turbo rebuilding two starter motors and wiring in some omex (the gucci bits).
Also had to give the servo pump some space so did that too, as you can see not all the manifold is new, this is because the old manifold i used (gti6) had all the right components i needed, also they were in good condition, i only had to buy 6 90 degree 38 mm bends to make it. all the pipes are withtin 10mm in length of each other too, (so it wont soumd like a bloody sh*tbox subaru Thumbs up )
the downpipe is only going to be 2.5" for a couple of reasons a: because the bore is sufficient and b: a 2.5" pipe is easier to fit in the hole. after the downpipe is made its going for ceramic coating, not sure on the colour yet though.
Well night night puggers am fooked so am going for a kip xxx
FATLAPIT
Posted 4th Mar 2012 at 01:59
clen666
Post #38
Good progress, this is turning into a nice project.
Would you be willing to knock up another one of those thermostat adaptors? Smile
Team 'unintentional rat look'
Posted 4th Mar 2012 at 10:11
fatlapit
Post #39
yeah not a problem, can only really do it when my car is done because i need every bit of time to try and get my car done for fcs, if i have a spare couple of hours i will do one and pm you pal. Thumbs up
Posted 4th Mar 2012 at 10:34
clen666
Post #40
That would be great, cheers mate Thumbs up
What size is the outlet?
Posted 4th Mar 2012 at 10:39
fatlapit
Post #41
its 50mm atm but i`m gonna machine a fitting to use the standard pipe without the horrible clip assembly. dont suppose you know what diameter the standard pipe is???
Posted 4th Mar 2012 at 10:43
clen666
Post #42
I'm not 100% but 38mm rings a bell
Posted 4th Mar 2012 at 11:14
Post #43
You need a 3" downpipe on a volvo to get 300+ bhp. 2.5" isn't big enough and makes it all run too hot.
Posted 4th Mar 2012 at 11:40
fatlapit
Post #44
Cheers for the comments but i will see what happens with the 2.5 system. also this aint my first turbo build.
Posted 4th Mar 2012 at 12:24
7057sam
Post #45
amazing work,how much has the project cost you already ?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 4th Mar 2012 at 13:02
fatlapit
Post #46
For an engine, with manis, plus metal for all the work. £300 all in. not bad when i have both manifolds a downpipe a bottom mount and a thermostat housing and a intercooler too.
Posted 4th Mar 2012 at 13:42
fatlapit
Post #47
just a quick snap before she goes to bed
couple of jobs to do, pull the turbo away from the body and pill the compressor towards the engine so its parrallel.
also remove the power steering cooler and fit a little oil cooler behind the r/h fog light for it. make mounts for the intercooler too.
Posted 5th Mar 2012 at 19:07
306 Rxs
Post #48
I was just thinking on doing the same to thermostat entry. Very well done mate. Wink
One doubt...how are you going to weld in the center of the 4 branch??
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 5th Mar 2012 at 19:34
fatlapit
Post #49
on the collector?? weld from the inside and then you can make a nice cone shape to promote good air flow Smile
Posted 5th Mar 2012 at 19:36
306 Rxs
Post #50
Thank you... Wink
I wonder how i didn't catch that sooner!!
What is a hybrid?
Posted 5th Mar 2012 at 19:59
