Author Subject: Rotrex C38 Series S/C Fitting Kit
rich_w
Chaps,
I have for sale a Rotrex C38 series supercharger fitting kit to suit the 2.0 16V XU engines. It was uneconomical to just get 1 off parts manufactured for Andy Rawson’s impressive conversion, so I had to increase the quantities of the parts to make it financially viable, given the machine set-up and tooling costs are substantial. This is essentially a spare set of parts I had made at the same time.
This kit differs considerably to the C30-94 fitting kit you may have seen previously.
Besides having a different S/C mounting bracket to suit the larger family of superchargers, it includes all the components required to change the entire auxiliary drive system from a 6 rib micro-v belt to an 8 rib micro-v belt. It is also designed to run with an aftermarket ECU, rather than the OEM ECU (we favour DTA). This means it’s designed as a conventional blow-through arrangement with the throttle body located on the inlet manifold (not on the inlet of the S/C). This set-up will require the use of a re-circulating dump valve and externally mounted MAP sensor (we use the Marelli / Cosworth 3 BAR sensors). A vacuum hose take-off is provided on the inlet manifold for this purpose.
The kit also contains a WRC style inlet restrictor / diffuser arrangement to control power, which was designed with some fluid dynamics input from Wayne Schofield. The restrictor / diffuser has been designed so the air-flow is not strangled until it reaches (or becomes very close to) terminal velocity. This means you won’t be restricting or losing power below the point at which it reaches peak power. This type of diffuser / restrictor is a lot more efficient than using a simple square edged aperture, like the restrictor rings we use on the low-boost conversion.
The kit comprises the following:
• Inlet manifold (colour choice / engraving can be completed to your specification)
• S/C bracket to suit Rotrex C38 series superchargers
• Tensioner & guide pulley for the above, to suit the wider 8-rib belt
• 8-rib alternator pulley
• 8 –rib alloy crankshaft pulley
• 8-rib alloy pulley for the OEM auto-tensioner
• Mounting spacers for OEM auto-tensioner (this is to space it out and centre it on the wider 8-rib belt)
• PAS pump complete with 8-rib pulley modification
• PAS pump relocation brackets
• New low and high pressure PAS hoses to suit the new location
• 8-rib S/C drive belt
• Alloy inlet housing for S/C (this houses the inlet air restrictor / diffuser)
• Inlet air restrictor / diffuser
• K&N air filter
• Alloy air scoop
• All nuts, bolts, washers etc.
This kit is £TBC
Photos to follow shortly.
Merry Christmas!
Smile
Contact Details:
07732 822546
Posted 15th Jan 2014 at 08:57
rich_w
Chaps,
Here are the photos of what’s included in this kit.
Modified auto-tensioner to allow use of 8-rib drive belt:
8-rib alternator pulley:
8-rib crank shaft pulley, hard-anodised:
8-rib drive-belt:
Inlet manifold to suit after-market ECU with bolted flange for T/B:
Fastenings:
PAS relocation bits and pieces:
Air filter:
Air Scoop:
C38 S/C bracket:
8-rib PAS pump:
Spacers for auto-tensioner:
Inlet air restrictor / diffuser and associated housing:
Contact Details:
07732 822546
Posted 27th Dec 2011 at 21:59
rich_w
8-rib pulley for auto-tensioner:
Contact Details:
07732 822546
Posted 27th Dec 2011 at 22:01
m306
Rich, will you be using that style restrictor ring on low boost conversions in the future?
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 28th Dec 2011 at 16:56
rich_w
No No
This restrictor is expensive to machine, , plus it's more difficult to integrate into the L/B setup where the throttle body is on the inlet of the S/C.
It would add £200+ to the price of a low-boost conversion, and isn't really necessary unless your chasing every last BHP everywhere in the rev range - which is what the C38 conversions are about.
Smile
Contact Details:
07732 822546
Posted 28th Dec 2011 at 18:09
MrMikaelEricsson
Rich, is the C38 S/C Bracket for sale as stand-alone part?
205 Monte Carlo GTI6 - 205 1,3 Rallye - Zender 205 - 205 CTI
Posted 13th Oct 2013 at 13:37
http://www.306gti6.com/forum/showthread.php?id=154489&page=2#41
Posted 13th Oct 2013 at 22:47
clen666
Don't think Lee would sell just the bracket seperately No No
Team 'unintentional rat look'
Posted 14th Oct 2013 at 08:28
superchargedblack1997gti6
Pretty sure that the cost of the bracket on its own would be uneconomical to produce on its own but I'm sure Rich will let you know.
Posted 14th Oct 2013 at 09:10
He may not, BUt if he want one quick there one there Smile
I doubt there will be any other knocking about
Posted 14th Oct 2013 at 11:55
ash
Six Addict
I had a C38 bracket made because mine got knocked and was out of true. It cost me £200 as a one-off and my engineers charged £100 for the initial programming so if I get one more made I'd like to split that cost, meaning I'd want £150 if one person was interested or £133 if two etc. This price isn't passivated but is available at an extra cost; I just gave mine a light dusting of satin black.
Posted 7th Nov 2013 at 11:36
MrMikaelEricsson
Ash: I have send you a PM
Posted 9th Nov 2013 at 12:09
ash
Six Addict
I've ordered 4 of these so there are two available at £150 each and they will be passivated gold like Rich's.
Posted 28th Nov 2013 at 13:22
rich_w
All,
I will be manufacturing some more C38 S/C conversion parts for a member on here.
Does anyone else require any parts made up?
It's extremely uneconomical to make one-offs, so if any one else requires any parts it will help bring the prices down for all parties.
Regards,
Rich Smile
Contact Details:
07732 822546
Posted 15th Jan 2014 at 09:00
MrMikaelEricsson
rich_w wrote:
All,
Regards,
Rich Smile
I am interested of a inlet manifold with fittings for the T/B (for use with a C38).
Is this avaliable or can be made ?
Posted 20th Jun 2015 at 20:32
rich_w
MrMikaelEricsson wrote:
rich_w wrote:
All,
Regards,
Rich Smile
Hi,
Yes, it's something I could make for you.
Please PM me with your requirements and I'll price it up for you.
Kind regards,
Contact Details:
07732 822546
Posted 29th Jun 2015 at 11:08
