Author Subject: Relays
simbob
Hi all I hope someone can help. I replaced my fogs and bulbs, they worked for an hour or so but now nothing, every time I turn the fogs on I get a click which means relay. Does anyone know for defo which relay it is and were it's located cheers sim
Happy to be back in a 306 again!
Posted 3rd Jan 2012 at 20:21
dan_s16
It's one of the green ones next to the fuse board (I just can't remember which one as it's been a long time since I had to look at mine), just put your finger on top of one of them and turn the fogs on and off, you'll soon find it.
If the relay is ok (pull it out once you've found it and make sure the socket and pins are ok and swap one of the other green ones over just to check it's not the relay).
Also check the fuses and earth points (I believe the fogs are grounded to the same points as the headlights, on the chassis rail behind each headlight).
Posted 3rd Jan 2012 at 21:19
simbob
Cheers dan
Posted 4th Jan 2012 at 01:00
