Author Subject: Airbag resistor
I've just fitted my old Sparco wheel to the China and was wondering if anyone on here knew off the top of their head the value of resistor I need to fool the airbag circuit into turning off the flashing amber warning light on the dash, thanks.
Posted 15th Jan 2012 at 11:01
fatlapit
1.8 fused ohm resistor
Posted 15th Jan 2012 at 13:06
Posted 15th Jan 2012 at 20:37
fatlapit
http://www.ebay.co.uk/itm/1-8-ohm-resistor-non-airbag-steering-wheels-Momo-X4-/320706185048?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aab940758
Posted 15th Jan 2012 at 23:31
mik
FAQ this?
Cherry Rallye SOLD
Posted 16th Jan 2012 at 16:55
russbez
if that definitely works then please
might be worth stating the obvious but….
quote:
Do not, under any circumstances, try to measure the resistance of an undeployed airbag . Almost all multimeters will put enough current through an airbag to make it go off when measuring resistance due to the fact the meter has a 9V battery in it that is used when measuring resistance, 9v is not 12v but it still possible to set off a airbag, unlikey but VERY possible.
Be safe, you could disconnect the air bag and fit one of the resistors that we sell and see if the light goes off.
My Rallye project thread
Posted 25th Jan 2012 at 12:13
russbez
i used a 20p(?) 1.8 ohm resistor Yes
had to use one on passenger side seat wiring
and a plug up near where the airbag plugs in
my airbag comes on..... and then goes off.
Took me long enough Roll eyes
never checked passenger side as it was the only plug that looks like it wasnt broken
Posted 26th Jan 2012 at 19:35
milkyb
I am fitting ph1 seats in a ph3, would anyone be so kind as to confirming whether this is the resistor i need to get to attach to the airbag wire on the car to trick the airbag light? (ie. the same for steering wheel and seat airbag wire?)
Posted 24th Apr 2012 at 14:49
milkyb
^ anyone?
Posted 27th Apr 2012 at 13:48
fatlapit
yes 1.8 ohm
Posted 27th Apr 2012 at 13:57
russbez
yep 1.8 ohm, same
LOL
Posted 27th Apr 2012 at 14:04
I know it's a very old thread but
Thanks guys Thumbs up
Posted 28th Mar 2015 at 08:01
