Author Subject: Cambelt snap
9Freedman9
Hi guys, I am new here so apologies if this is in the wrong forum, I have purchased a 306 gti on an R plate with a failed cambelt, I am yet to remove the head and check for damage but I am pretty sure it's just the valves bent.
I have a list of the parts I need, which are;
1) Complete head gasket set.
2) Set of head bolts.
3) Inlet valves x 8.
4) Exhaust valves x 8.
5) Engine oil & oil filter.
6) Anti-freeze.
7) Timing belt kit.
8) Water pump (may not need it at the end of the day).
Obviously there may be some bottom half work needed, but what is the propability of this? How much are these parts and where would be the cheapest place to get it all from? I will propably leave the waterpump, what do you all think?
I do not want to go down the other engine route as I know the engine is pretty good in the car, it was previously owned by a member on here, I will upload a picture as soon as I find out how too!
Posted 15th Jan 2012 at 15:06
anth
Definitely replace the pump while your there!
Posted 15th Jan 2012 at 15:08
jeffers Forum Admin
In all honesty I would remove the head before buying anything, if it's damaged a piston it would be much more economical to fit a second hand engine, but don't make any decisions on what's needed til u've checked the damage!Wink
Team Running Engine again!
Team Negative Camber!
Posted 15th Jan 2012 at 15:14
9Freedman9
You have to be unlucky to have damaged a piston though surely? Even a conrod etc? What about sleve liners? Will they be ok?
Posted 15th Jan 2012 at 15:23
Known to damage pistons Yes
Can't think of the threads which show the damage but it's not uncommon.
Posted 15th Jan 2012 at 15:31
Mikey S
to be honest, it'll be more down to what speed the engine was turning at to whether its damaged the pistons or not. idle speed and it'll probably just be bent valves but 6000rpm maybe a bit different! as above though, ALWAYS change the waterpump and make sure you have the head rebuilt by a confident engine builder who will check the valve guides as well.
remove the head before stumping up any cash for engine parts.
mike
Onyx Black '6, 1997.
Graphite Grey MI16 205, 1990.
Hanover Green Pajero 2.8, 1995.
Midnight Sky Galaxy TDCI, 2011.
Team: Dented Quarterpanel....
Posted 15th Jan 2012 at 15:39
csm
Mine snapped at idle in october last year.......... 5 bent valves was the outcome
Posted 15th Jan 2012 at 15:43
9Freedman9
It was pulling away in first when he heard it/felt it go, so he pulled over straight away and turned it off!
Posted 15th Jan 2012 at 15:44
ryangti6
Make sure you also change the valve guides, these and bent valves being missed are the most common causes of these engines tapping after a rebuild.
Ryan
Posted 15th Jan 2012 at 16:47
No use surmising. You won't know until you get the head off and assess the extent of the damage.
  • Posted 15th Jan 2012 at 16:53
    jeffers Forum Admin
    I agree, but don't count on anything til u remove the head and check, if the bore is damaged the block is scrap also which could easily happen if the valve head comes off or even just a piece breaks off.... Check the condition of everythin before making a decision on a fix.
    Posted 15th Jan 2012 at 16:54
    miles
    No need to change the guides as they rarely give any issues, the amount of heads I have done and yet to replace any of them.
    www.pugracing.com
    Posted 15th Jan 2012 at 20:27
    pistons made from cheeese!
    Posted 15th Jan 2012 at 22:50
    jimmyhackers
    heres what a snapped cambelt will do
    Posted 15th Jan 2012 at 23:11
    Rich E Forum Admin
    That's not from a cambelt failure.
    There are no marks on the other pistons and the valves from the rest of the cylinders seem okay.
    Posted 15th Jan 2012 at 23:19
    jimmyhackers
    oops sorry....your right. wrong photo.
    my bad Sad
    i cant find the other ones of my mates golf that happened the other month. similar extent of damage. engine ate itself apart.
    id suggest taking it apart and seeing the extent of the damage then thinking........"i need a new engine Sad"
    Posted 16th Jan 2012 at 00:04
    that'd be a result of driving a tapper Thumbs up
    Posted 16th Jan 2012 at 10:05
    Indeed it is, but the amount of people that still do it is shocking. It is a known fact that tappers WILL cause dropped valves at some point in the life of the engine, but it isn't considered a big enough risk by most to bother doing anything about it.
    Posted 16th Jan 2012 at 11:49
    Guides need checking though while its in bitsThumbs up
    I bought a head that was not off a snapper and all the exhaust valve guides needed replacing due to wear,so while the head is off and in bits they need checking.
    Posted 20th Jan 2012 at 10:19
    Yes, the guides should deffo be checked. I must admit, I have yet to find some that need replacing but generally after a snap and valves have been bent, the end of guides can get damaged so always worth checking. Yes
    Posted 20th Jan 2012 at 10:41
