Author Subject: Stalling when coasting in neutral
hsustyle
I just did a coolant drain and flush because the old coolant looked a bit dirty. Flushed the system properly and bled well.no bubbles or air etc.doesn't go near 90c. Went for a drive,temp stays down nicely,levels fine etc. This afternoon I popped 2miles down the road and the engine stalled when i approached a junction in neutral. Revs died. It fires up fine,sounds and drives fine and the temp and coolant is fine.it did it again just now when i went to park up. Any ideas? It didn't do this before I decided to drain coolant.
Beef Beyond Belief
Posted 23rd Jan 2012 at 15:41
hsustyle
Also there is hesitation in the lower revs when i put my foot down.
What sensor could cause that? Tps?
Beef Beyond Belief
Posted 23rd Jan 2012 at 16:07
likely to be that i think
Posted 23rd Jan 2012 at 16:44
idle valve.
does your speedo work?
most things can be tested with a multimeter though, check the faq
Posted 23rd Jan 2012 at 17:16
hsustyle
idle valve.
I've unplugged and replugged icv,Tps and map sensor and it still does it.speedo works fine.
Beef Beyond Belief
Posted 23rd Jan 2012 at 17:41
that wont fix a worn/damaged item LOL:
Posted 23rd Jan 2012 at 17:49
hsustyle
ShhhhWink
Beef Beyond Belief
Posted 23rd Jan 2012 at 17:55
aaron6
Try cleaning the icv. That often fixes the stalling issues. If not, you'll have to but another I reckon. Smile
As others have said, ICV clean is the first thing to do.
If this doesn't cure it then you will need to buy new. Keep an eye on the accelerating from low RPM, as thats a typical lambda fault. If this symptom continues, keep a check on how much fuel your getting through. If it seems excessive, then your lambda will need changing.
But hopefully for now, an ICV clean should see you right. Smile
Stan.
Posted 23rd Jan 2012 at 18:10
hsustyle
Cheers Stan. I'll keep an eye on it over the next few days.
Beef Beyond Belief
Posted 23rd Jan 2012 at 18:50
hsustyle
Ok i have cleaned Icv, Tps and map sensor and ir still jumps to 2k revs when I start it up.instantly drops to 900rpm again. There is a hesitation between 1k-2800 revs and sometimes just cuts out. Pulls hard and smooth after 3k revs.
Ahhh soo annoying.
Beef Beyond Belief
Posted 27th Jan 2012 at 17:54
Ahhh soo annoying.
That is classic lambda fault symptoms. Sad
Posted 27th Jan 2012 at 19:00
hsustyle
Good to know.I'll be after a new one then! Ah well,could have been worst.
Beef Beyond Belief
Posted 27th Jan 2012 at 19:06
