Author Subject: do peugeot do a normal rad?
fatlapit
hi i need a rad that doesnt use the "clip n o ring" method, also i need a none that does not have the inlet for the heat exchanger.
cheers chris
Big grin Big grin Big grin Big grin Big grin
Posted 28th Jan 2012 at 22:12
Early type rad and cap off the heter exchanger bit Thumbs up
Posted 28th Jan 2012 at 22:14
fatlapit
so would an early 1.8 one be the same without the heat exchanger bit??
Posted 28th Jan 2012 at 22:17
fatlapit
what year we looking at
Posted 28th Jan 2012 at 22:20
By heat exchanger bit you mean the small outlet on the back of the rad ? Why not just block this off if you don't need it ?
No idea what the 1.8 rad looks like I'd say it was similar to a 6 but could be wrong ?
Posted 28th Jan 2012 at 22:21
fatlapit
it will look horrible
Posted 28th Jan 2012 at 22:22
Phase 1 up to 97 or maybe some phase 2 earlys s reg or before they come with the early clip type connection Thumbs up
Posted 28th Jan 2012 at 22:30
Dude it's on the back of the rad who will see it ? Accept the oil filter ?
Posted 28th Jan 2012 at 22:31
fatlapit
fair one
Posted 28th Jan 2012 at 23:07
chrisd306
I changed mine to use the clip and o ring instead of the old style as much easier, swapped the water hose although I need a bigger rad as gets to hot after 18laps roughly 20mins flat out
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 28th Jan 2012 at 23:22
I believe some of the XSi rads do not have the heat exchanger take off on the rear of the rad...Yes
Posted 29th Jan 2012 at 09:46
205 rad Smile
Posted 29th Jan 2012 at 12:17
fatlapit
But then u need a header tank
Posted 29th Jan 2012 at 22:32
I am sure the XSi one will do the job, its essentially the same as the GTi-6 one without the heat exchanger take off. Wink
Posted 30th Jan 2012 at 10:33
phase1 xsi has two small ports on the expansion tank plus the bayonet type bottom hose, phase 2 has the clip type and a blanked heat exchanger takeoff, though personally I'd just use the 6 rad and the heat exchanger.
https://webshop.nissens.com
Posted 30th Jan 2012 at 11:10
jimmyhackers
just a thought. but on my phase one the front reg plate blocks some air flow to the rad. if its a track day problem you could remove this to help a bit with overheating, not so sure if the same blocked vent exsists on the later phase 2 and 3 models :s
also cleaning a coil (rad) with proper "coil" cleaner can increase efficiency by upto 50% if its really dirty. you can buy this from hrp or climate control stores pretty cheap. cleaning the inside is as important as the outside.
Posted 30th Jan 2012 at 16:27
chrisd306
jimmy i run mine with out front number plate also with large diameter holes in bumper also with front griil and lower grill butchered to aid cooling probly the intercooler infront of rad not helping, but the rad i have is deff smaller then a genuine pug one, think i was told it was a derv rad i wanted as its the largest i think. also the rad is fairly new.
& Audi Q5 S Line
Posted 30th Jan 2012 at 16:46
