Thanks, Tom
| Author | Subject: Snapped wheel bolt |
tomlum
Regular Location: Lincoln Registered: 17 May 2011 Posts: 210 Status: Offline |
While putting the cyclone back on my car this week i was tightening up the bolt and it just went like butter! Now its left half the bolt screwed into the hub. What is the solution to this?Thanks, Tom |
russbez
if you can get the wheel off, which id imagine you caneither get a decent pair of vice grips on to it or if there is only a small bit of broken bolt sticking out you could get someone/garage to weld a bolt onto it and attempt to remove it then ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
You willn need to try to drill it out or buy a new hub.________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
mark.evs
Senior User Location: Near Bridgend Registered: 21 Dec 2010 Posts: 527 Status: Offline |
I've had this, Take off the disc and there should be enough stud to get a grips on it. I bought a 306 a while back and someone had previously used exhaust paste to stick the bolt heads back into the wheel. 2 studs on the 1 wheel! ________________________________________ My GTi6 track projectWhite Rallye project |
russbez
mark.evs wrote: I've had this, Take off the disc and there should be enough stud to get a grips on it. I bought a 306 a while back and someone had previously used exhaust paste to stick the bolt heads back into the wheel. 2 studs on the 1 wheel! good idea! haaaa major bodge there eh!! you wouldnt think to check that sort of thing before you buy it ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
p.s welcome to General section on the gti6 forum![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
tomlum
Thanks for the advice guys! |
stan_306gti6
mark.evs wrote: I've had this, Take off the disc and there should be enough stud to get a grips on it. I bought a 306 a while back and someone had previously used exhaust paste to stick the bolt heads back into the wheel. 2 studs on the 1 wheel! It is quite worrying that there are people out there that will carry out this sort of behaviour! ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
antcla.85
Senior User Location: Southampton Registered: 18 Dec 2007 Posts: 580 Status: Offline |
Just get a snap on stud extraction set. Drill hole, put in extractor, turn, wind stud out.________________________________________ Life is short, make it interestingBuy a Peugeot! |
russbez
vice grips should manage________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
stan_306gti6
antcla.85 wrote: Just get a snap on stud extraction set. Drill hole, put in extractor, turn, wind stud out. This is a good method provided the stud extractor doesn't snap whilst in use. As they are hardened it is very difficult to try and drill them out if that happens. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
agreed, I would only use an extractor as a total last resort, best bet is to try and drill slowly with a very sharp bit and plenty of lube.then wallop a decent sized torx bit in and wind it out. that's if you can't just tap it round with a chisel then get some grips on it. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
If you can get it to a garage, have them weld a nut on the end of it and try it that way. The heat will help loosen things up tooDid this to mine the first tyre change I did, but in my case, it was due to the shit locking nut key being made of cheese ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
gtisid
Seasoned Pro Location: chelmsford Registered: 22 Mar 2003 Posts: 4,992 Status: Offline |
if you are a member of the aa get him round as he will have the extractor kit, been a member of the aa for donkeys years and they were only too pleased to help. did not even have to get out of the chair. still paying 240 a year for a years membership so it made sense as i had overtightened all my wheel nuts and f*cked the locking wheel nuts. did not know my own strength despite changing tyres for the first year of my life after i left school! it would appear though that scooby gt wheels have a oversized counter sink on them though and the nuts just bury themselves in them if you over tighten them! lesson learned________________________________________ puglessPhase 1 GTI 6 1996-1997 Subaru Impreza GB270 2007-2008 rare spiderman comics same day international courier |
heidi6
Regular Location: Cornwall Registered: 30 Nov 2011 Posts: 409 Status: Offline |
Seriously, S/O easy outs. The best £50 you'll ever spend. As long as you've got 3-4mm sticking out you'll have the bugger out. ________________________________________ IPhase 3 Astor. Built on Wednesday, 12th April 2000 in France. Years of 'Creative Maintenance' mean this car is now much lighter and slightly more 'race' specced... |
if there's that much sticking out I doubt you will need any tools.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mechanical_repairs
gtisid wrote: if you are a member of the aa get him round as he will have the extractor kit, been a member of the aa for donkeys years and they were only too pleased to help. did not even have to get out of the chair. still paying 240 a year for a years membership so it made sense as i had overtightened all my wheel nuts and f*cked the locking wheel nuts. did not know my own strength despite changing tyres for the first year of my life after i left school! it would appear though that scooby gt wheels have a oversized counter sink on them though and the nuts just bury themselves in them if you over tighten them! lesson learned Jeez some of the locking nuts we get here with no key are a nightmare to remove, i might try the aa approah,i also pay a yearlymember fee thats mental. ![]() Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
