Author Subject: low boost missfire
mrdeey
my car has developed a missfire over 5000 revs , i have checked for air leaks and changed the map sensor but still persists any ideas ?Sad
now new booted , boosted and flying again!
Posted 20th Feb 2012 at 19:05
woody.
Not sure but I'd check the coil packs in case
Posted 20th Feb 2012 at 19:11
aaron6
You got your own personnel map or on the generic map? I believe lee has this and has spent a small fortune to no avail. I believe its down to the copied map and if it was mapped to that engine that the engine would run spot on.
Posted 20th Feb 2012 at 19:40
nothing to do with fuel starvation?
Posted 20th Feb 2012 at 19:45
mrdeey
it did run spot on when i first converted it several months ago , but its returned , i had a problem after the first run which turned out to be a coil pack , but how do you test the things?
Posted 20th Feb 2012 at 21:58
mabgti
NV motors
Knackered fuel pump and regulator!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Feb 2012 at 23:06
rich_w
Clive,
I would check the coils first off - I may have a spare set I could send you if you get stuck?
Smile
Contact Details:
07732 822546
Posted 20th Feb 2012 at 23:53
It does sound like a dodgy coil pack I must admit. Yes
Posted 21st Feb 2012 at 08:13
mrdeey
update chaps , car is now running correctly it was........................................... indeed a dodgy coil pack , thanks for all the replies
Posted 28th Feb 2012 at 15:30
mrdeey
now not running correctly , had one run with the replaced coil packs then the symptoms returned ! grrrrr friggin thing , i have put a new set of plugs in as well , seems like an early rev limiter , not sure if its down on power lower down as well , it has a new lamda , iv changed the map sensor and icv , going to try leaving the battery disconected overnight and see what happens , dodgy ecu? head gasket ? does not seem to use any water though
Posted 6th Mar 2012 at 22:18
mrdeey
checked and double checked all the sensors and coil packs and plugs , will rev fine stationary but not under load , fuel pump? regulator? if so how do i check them?
Posted 7th Mar 2012 at 16:32
check the FAQ section.
Posted 7th Mar 2012 at 16:43
smegal
Does it have a cat?
Ex SC-6
Now in a Megane R26
Posted 7th Mar 2012 at 16:47
mrdeey
decat pipe fitted with a new lambda sensor
Posted 7th Mar 2012 at 16:50
smegal
What are the exact symptoms?
Ex SC-6
Now in a Megane R26
Posted 7th Mar 2012 at 16:55
mrdeey
miss fire and no power after about 5000rpm but only under load , seems to rev fine when stationary
Posted 7th Mar 2012 at 16:57
smegal
The lack of power after 5k is what mine did when the cat was kanckard. I would look at your exhaust in case something has gone wrong with that.
Ex SC-6
Now in a Megane R26
Posted 7th Mar 2012 at 17:41
mrdeey
exhaust looks fine , i could try swopping over my old lambda and see if it makes any difference
Posted 7th Mar 2012 at 18:03
rich_w
Check fuel flow rate on the rail return as per my text.
Did you want to send me the ECU to look at / test?
Smile
Contact Details:
07732 822546
Posted 7th Mar 2012 at 18:35
mrdeey
Fuel pump was the problem , changed the regulator as well as I had damaged the O rings , don't bother trying to find replacements , just get a Bosch 3bar one from a golf , the seals are better (green ) , mine cost me £2.00 complete !
Posted 25th Mar 2012 at 12:00
So a pump from a golf is a direct swap for ours?
Posted 25th Mar 2012 at 12:19
mrdeey
No , just the regulator
Posted 25th Mar 2012 at 13:15
Does it handle "like a golf" now then? Whistle
Posted 25th Mar 2012 at 21:53
mabgti
NV motors
Game.. set... And match!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 25th Mar 2012 at 22:03
mabgti
NV motors
NV Motorsport
0121 448 7515
Facebook Page
Project S6
