displaying posts 26 to 50 of 64
Pages (3): 1 [2] 3
Author Subject: Fecking car won't start- update!!!
peetypug wrote:
FFS!!
just come to collect the piece of shit and it won't start!
Oh dear. Sad
You need to check whether you're lacking fuel or spark. Yes
Posted 25th Feb 2012 at 17:04
peetypug
Both again!
Just swapped the relay back and it started
Turned it off and it wouldn't start!
Tried again and it started
It used to fire instantly, now it takes a second Dunno
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 25th Feb 2012 at 17:29
peetypug
Crank sensor??
Posted 25th Feb 2012 at 17:30
I would be surprised if it was the crank sensor as these are not usually intermittant.
When it doesn't start does the fuel pump still prime?
Posted 25th Feb 2012 at 17:41
peetypug
Could it be thy it's dropped a tooth on the flywheel or even some crap making it not read correctly?
I've been told they might use the crank sensor to start then the cam sensor when running??
Posted 25th Feb 2012 at 17:43
Cam sensor is used on starting but then redundant once the engine is running. It could well be that, but I haven't seen one of those fail for years.
Posted 25th Feb 2012 at 17:52
dan86
It's a long shot but worth checking the two plugs under the dash above the the passenger footwell. They can get kicked and come loose. The fuel pump feed is part of that interior loom. It won't cost anything to check. I think one plug is red and the other is brown.
Posted 25th Feb 2012 at 18:03
peetypug
Fuel pump is priming, but the injectors aren't firing
Posted 25th Feb 2012 at 18:05
Sounds like an intermittant immobiliser fault, although it is an odd one.
Have you checked your earthing points incase they are causing intermittant faults?
Posted 25th Feb 2012 at 18:10
peetypug
Post #35
Earths are fine, they were cleaned up 8 months ago
Posted 25th Feb 2012 at 18:20
peetypug
Post #36
defo not earths, i used jump leads and earthed the battery to the block and the block to the chassis
defo not the double relay (tried 3 and it has ran on all of them today)
all the pins on the ecu look fine
Posted 25th Feb 2012 at 18:46
eddy_gti6
Post #37
Fuel cut off switch under the bonnet?
Posted 25th Feb 2012 at 18:57
Post #38
Are you definitely sure you don't have fuel AND spark?
Posted 25th Feb 2012 at 19:04
peetypug
Post #39
right, got it started and im now home, drove sweet as a nut for all 25 miles
my mate told me to put both jump leads onto the negative of the battery
then put one on the gearbox near the crank sensor and the other onto the top mount of the engine
turned it over and nothing, tried again and it started. so didnt turn it off and drove home
just got back, turned it off, tried again and it started.
i bet it wont start again in 10 mins though Sad
Posted 25th Feb 2012 at 19:59
peetypug
Post #40
yes mate
tried easy start and it wouldnt fire, it didnt even try to start
then took a plug out after cranking it over and theres no smell of fuel and the plugs were dry
so Dunno
Posted 25th Feb 2012 at 20:01
peetypug
Post #41
I think I've found the issue Sad
Immobiliser, took the ecu out and swapped it for an unlocked one
It started Thumbs up
So put all the bits back on, then went to start it again
Guess what?? It wouldn't start Sad
So tried another unlocked ecu and it started, I've taken that one off so it's still unlocked
It's got to be immobiliser issues Sad
Posted 25th Feb 2012 at 22:22
Post #42
probably the aerial around the lock barrel, very common on 106's, I think the 306 part is the same.
Posted 25th Feb 2012 at 23:16
peetypug
Post #43
i swapped that for another but no luck Sad
are they matched to the chip in the key? or is it just a reciever that would work on any car?
Posted 25th Feb 2012 at 23:18
Post #44
It certainly does sound like an immobiliser fault. How exactly have you checked you have no spark?
Posted 26th Feb 2012 at 07:37
peetypug
Post #45
Just with easy start, that stuff would start anything!
Posted 26th Feb 2012 at 07:44
Post #46
I disagree. You should have taken a coil and plug out of the head, put the plug back in the coil and then earthed the threads of the plug on the head somewhere. Then got someone else to crank it over whilst you watched to see if the plug was sparking or not. Yes
Posted 26th Feb 2012 at 08:06
peetypug
Post #47
I did that with the rac guy and wasn't getting spark
Posted 26th Feb 2012 at 08:22
Post #48
Ok, well with that diagnosis and the fact you've had it running on two separate unlocked ECU's I would put my money on an immobiliser problem. Can you not just fit the unlocked ECU and keep it on there for a week to test it out?
Posted 26th Feb 2012 at 08:26
peetypug
Post #49
I dud that last night and it locked one of my unlocked ones Sad
Posted 26th Feb 2012 at 08:30
Post #50
Yes, it will do when you turn the ignition off the ECU will lock to that system. Yes
Does that same ECU now not work?
Posted 26th Feb 2012 at 08:39
Pages (3): 1 [2] 3
