Author Subject: V6 gear box
yadam
Do any other gear boxes fit on the 406 v6 1998 engine
Posted 1st Mar 2012 at 00:49
Why whats the problem? Any ML box would fit. I'd have thought there are quite a few renault boxes that fit too.
Posted 1st Mar 2012 at 09:43
I believe the V6 has its own bellhousing.
Posted 1st Mar 2012 at 10:30
f*ck.
Posted 1st Mar 2012 at 12:00
indeed, lots of them about though, and I'd imagine the internals from another ML could be swapped.
quite strong boxes all told, some 5th gear issues on some IIRC but that may have been the older ME gearbox.
whysat?
Posted 1st Mar 2012 at 12:16
yadam
I don't no much if any thing about gear boxes. What I was hoping is that I could put a diffrent box on to sort out the hydrolic clutch but now I'm thinking could I gt the pedal box from the 406 and weld in has any body heard of this
Posted 1st Mar 2012 at 21:45
Yup that's exactly how you do the conversion bud 406 peddle box welded into a 306 bulk head Thumbs up
Posted 1st Mar 2012 at 22:06
And the stabiliser mount as well
406 pedal box wont fit directly, its a right old bodge making it fit.
I have heard of a hydraulic clutch master being fitted to the 306 pedal, possibly a late berlingo/partner, unfortunately the pedal box is a different shape, the earlier vans ere the same bulkhead but never used a hydraulic clutch.
you don't want to use any other gearbox on this engine.
Posted 1st Mar 2012 at 22:09
yadam
Ok have u heard of these http://pitstopusa.com/i-5063193-cnc-swing-mount-clutch-pedal-assembly-w-3-4-master-cylinder.html could I fit this
Posted 1st Mar 2012 at 22:46
I'd just get hold of the original master cylinder and offer it up, save yourself a lot of work trying to figure out what size and stroke MC to use.
Posted 1st Mar 2012 at 22:57
yadam
Ok I just dont understand how that works
Posted 1st Mar 2012 at 23:19
time to start learning faaaast if you're thinking of doing an engine conversion!
Posted 1st Mar 2012 at 23:30
yadam
Yea mate well I gt car, loom , exhaust, ecu ,driveshafts oh and the engine of coarse so far
Posted 1st Mar 2012 at 23:38
My V6 rallye build
V6 wiring diagram download - match up the numbers on the wires...
Its a bit of an arse that conversion.
Posted 2nd Mar 2012 at 09:53
