I'll check the FAQs, i think there is mention of it in there somewhere
Who would be best equipped thi fix this (properly) should it require doing - Carl? Daveyboy?
Team: Moonstone GTI-6™Team:
displaying posts 26 to 35 of 35
Pages (2): 1 [2]
| Author | Subject: Knock From Lock to Lock |
davewagon
Senior User Location: Corby / Northampton Registered: 21 Feb 2007 Posts: 889 Status: Offline |
Thought soI'll check the FAQs, i think there is mention of it in there somewhere Who would be best equipped thi fix this (properly) should it require doing - Carl? Daveyboy? ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
davewagon
Is there any special things to take into consideration when jacking up the engine?Where is safe to put the jack, block of wood to spread weight? ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
stan_306gti6
Block of wood on top of the jack and then jack the engine up via the sump at the cambelt end. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
davewagon
Thanks a lot guys________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
stan_306gti6
No problem, hopefully its not that, but it needs checking out first. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
davewagon wrote: Thought so I'll check the FAQs, i think there is mention of it in there somewhere Who would be best equipped thi fix this (properly) should it require doing - Carl? Daveyboy? any welding torch wielding non-muppet ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
davewagon
After looking under my car, I've discovered that my droplink has completely snapped away from the ARB.So for the time being i'm going to assume this is causing my 'knock' rather than ropey engine mount. The local factors (Parkers - "the parts people" sell droplinks by FAI for £18ea (not Lemforder, which the last ones were)Does anyone have any experience of these, or am i best off going for Lemforder again (even though it didn't last all that long )Or fork out £80odd for rose jointed jobbies on ebay? (probably not) Regards, Dave ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
stan_306gti6
You don't need the rose-jointed ones...FAI are a good brand and they are fine, I used to sell these, and I think I may have a set fitted to my car. Can't remember it's so long ago I fitted them. ![]() Either FAI or Lemforder will see you right Dave. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
davewagon
Stan the man! Cheers again!________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
stan_306gti6
Post #35
No worries mate. ![]() Now that you've tackled removing/refitting the inlet manifold these should be a walk in the park... ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Pages (2): 1 [2]
