Author Subject: Amp to Headunit wiring problem
roddo
Hi, Does anyone know where I put the "orange coloured" power cable approx 5mm in diameter, that runs from the Amplifier to the headunit, I think it switches the Amp on when the headunit powers up.
I can see where it goes in my Sony head unit its connected to the blue/white wire, but my pioneer headunit (DEH-P9600mp) does not have a blue/white wire, only a "wired remote input" 3.5mm jack, could this be where it plugs into ???? I'm Confused Sad Sad
Posted 3rd Mar 2012 at 09:06
I assume you have a power line from the car battery t the amp ? If not then that's what that wire is for ? The remote turn on is usually a very thin wire (blue) from the head unit with a label showing remote on it ?
DO NOT WIRE THE AMP FROM ANY OTHER POWER SOURCE OTHER THAN THE CAR BATTERY AND ALWAYS USE AN IN LINE FUSE Thumbs up
Posted 3rd Mar 2012 at 09:20
aaron6
What other wires do you have? As normally its
Red-live (battery to amp)
Brown-earth (amp to earthing point)
Blue (thin)-remote (head unit to amp)
Red & white rca cable. (head unit to amp).
Posted 3rd Mar 2012 at 15:59
swiftyboi006
^this Thumbs up
Black p3 Love
Posted 5th Mar 2012 at 19:57
roddo
This is the orange wire/cable currently connected to the thin Blue/white wire my Sony Headunit,
roddo has attached the following image:
Posted 5th Mar 2012 at 22:50
So have you you got power and earth to the amp as well ?
Posted 5th Mar 2012 at 22:53
roddo
This is where I think it should go on my Pioneer Headunit, but I'm not sure Sad It is I think 3.5mm size, which I think the Orange wire/cable fits in to, what do you think fellas ??? I'm stumped !!! Next stop auto electrician Sad
Posted 5th Mar 2012 at 22:59
roddo
[Yes I think so, I had everything installed by an auto electrician, so i'm sure its a proper job]
Posted 5th Mar 2012 at 23:03
I don't think so bud ? The remote turn on is usually a thin wire get a multimeter on the wires from the head unit and find the the 12v signal wire when the head unit is turned on ?
Maybe a pic of what has been wired where would help ?
Posted 5th Mar 2012 at 23:34
aaron6
Plug it in and play. If you have fuses in the amp and stereo nothing should blow. But yeah, normally the remote is a thin blue wire. Can you post pictures of all the wires on the head unit?
Posted 6th Mar 2012 at 07:01
footah212
Is that plug not for some sort of steering column controller for the headunit?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 7th Mar 2012 at 11:31
roddo
just spoken to my Auto Electrician who installed my sound system, and that black remote lead is not for my orange amplifier cable, so I'm not gonna risk damaging my I.C.E., I'm taking it to him to sort out.
Thanks for everyones in put
Thumbs up
Posted 7th Mar 2012 at 22:55
