displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: V-power... hesitation?
The reason that the vehicle handbook suggests running on 97 is because the '6' engine in standard form is 10.8:1 compression which is fairly high. However, due to the fact that a lot of people will just run normal 95 regardless of the suggestion the engine has been set up with a knock sensor to compensate for the possible different fuel choice of the owner. With this, the ECU can detect when detonation is about to occur and retard the ignition timing...
Personally, I use V-Power specifically due to the advanced cleaning agents in the fuel (so they claim) being present. Wink
Posted 9th Mar 2012 at 11:40
Knock is when the fuel ignites before the spark has been introduced. Caused by having too low octane rating or high intake air temps.
Incorrect
They're often confused, but knock and pre-ignition are *not* the same thing. Knock is an incorrect or uneven burn (but initiated by the spark plug) whereas pre-ignition is caused by wrong fuel or over-compression; i.e. when the fuel is ignited by pressure rather than a spark.
Posted 9th Mar 2012 at 11:45
Incorrect
Fair enough. You'd better go and change a load of pages i've just read on the internet then LOL Thumbs up
Posted 9th Mar 2012 at 11:47
'Knocking' is where the fuel/air combination begins to combust in the correct manner initiated by the firing of the spark plug, but some of the mixture explodes outside the area of the main flame front.
'Pre-ignition' is where the fuel/air combination is ignited in the combustion chamber without the help of a spark plug. This can be caused by extreme pressures (mixed with low octane fuels), hot spots in the chamber or incorrect temperature of spark plug selected.
Posted 9th Mar 2012 at 12:24
jimmyhackers
ive been invited to stick my oar in
the higher octane is created by adding percentages of other chemicals mainly bio-alcahols like ethanol and methanol. essentially its a gimik of sorts
these also act as detergents to a degree as they are solvents. however its possible they could melt or corrode other parts of the fuel system creating "stuff" to make deposits further along the system.
my friends mev rocket exploded a fuel line that had been softened because he was using morrisons stuff with a percentage bio-fuel added.
Posted 9th Mar 2012 at 16:13
woody.
Cheers for the info lads Thumbs up
Posted 10th Mar 2012 at 23:36
mattgti6phase2
V power is no cleaner than 95 sir.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 11th Mar 2012 at 01:32
Reference to origin of information Matt? Unsure
Posted 11th Mar 2012 at 15:28
mattgti6phase2
Perhaps the way 97 fuels are marketed lead people to believe all these out ragious statements Dunno
In actual fact the main difference between the 2 are the anti knock properties being better in 97 fuels over 95. I have used both fuels and even tescos w*nky 99 fuel and the difference is nothing on my internally standard engine.
Although I do find my engine is happier to run on 95. Again my engine internally is standard.
5 x a 306 owner!
Posted 12th Mar 2012 at 02:17
Post #35
There have been tests done where people have bench ran engines with a twin-tank setup. One tank of standard 95 is feeding two cylinders and V-Power is feeding the other two.
It ran like this for weeks, and then they stripped it down. The V-Power cylinders were A LOT cleaner than the ones that had been run on standard fuel. Yes
Posted 12th Mar 2012 at 07:12
mattgti6phase2
Post #36
This debate is pointless LOL
Its simple, no power gains are to be had unless your SC TB or turbo'd and your Ecu has been set to run that fuel. Deffo no cleaner between the two though.unless i saw evidence of it, fuel experts say the cleaning differences are nil.
5 x a 306 owner!
Posted 12th Mar 2012 at 11:00
swiftyboi006
Post #37
But stan just said it was tested? (stan you must be talking bulls**t) Laugh my ass off
Black p3 Love
Posted 12th Mar 2012 at 19:26
Post #38
Obviously mate, after all what do I know about these things...Whistle
Posted 12th Mar 2012 at 23:58
mattgti6phase2
Post #39
Roll eyes
5 x a 306 owner!
Posted 13th Mar 2012 at 01:05
Post #40
Could it not just be the Lambda Sensor on its way out? Dunno
Posted 13th Mar 2012 at 02:54
Pages (2): 1 [2]
