Author Subject: pulley question
fatlapit
are the gti6 crank pulley the same as the 2l 8v turbo one??
as you all know the harmonic pulleys are crap and the outer spins, i have a brand new 2l 8v turbo crank pulley to use to time up the motor providing its good!
Posted 4th Mar 2012 at 22:02
tony eastwood
dont know
Posted 5th Mar 2012 at 11:49
also don't know
Posted 5th Mar 2012 at 12:20
fatlapit
any one?
Posted 5th Mar 2012 at 18:53
I think they are the same, but the offset, diameter and number of grooves might be different, ask Miles as I think he knows them.
Posted 5th Mar 2012 at 18:59
fatlapit
im hoping the timing marks/holes are the same
Posted 5th Mar 2012 at 19:04
info@pug1off.com
Diferent offset to accomodate the differnt belt width, but the mark will be the same....all pistons level with 1 and 4 rising in the direction of rotation if you ever want to check the accuracy of a pulley!
N/A XU10J4RS = 302.1 bhp / 184.2 lb.ft
Turbo XU10J4RS = 500.2 bhp / 443 lb.ft
USC 2011 Double Class winners
N/A FWD 0-60 winners at TRAX 2011
Developers, stockists and installers of superior upgrades for the Peugeot 306 GTi6 & Rallye, including:-
*NEW!!!!! 4.8:1 final drive for BE3/6
*BBM Group N engine mounts
*Cat Cams and vernier pulleys
*Emerald ECU's
*Jenvey throttle bodies
*Uprated gear linkages and short shifts
*Quaife & Tran-X LSD's for BE3/6
*Tar-Ox brake discs and Ferodo DS2500 pads
*Solid rear beam mounts
*21-25mm torsion bars
*25mm rear anti roll bars
Posted 5th Mar 2012 at 19:56
fatlapit
also when timing the gti6 motor with the stock adjustable cam pulleys, how do you set the pulleys?? are they set the same?? or fully advanced or retarded??
how much to set the timing lol for a turboed motor??
Posted 5th Mar 2012 at 19:59
neither, you pin the bottom, pin the top, swing the pulleys forwards the fit the belt, tension the belt then tighten the bolt/s on the pulleys.
Posted 5th Mar 2012 at 20:21
fatlapit
oh i see the cams are hels when you tension the belt so the timing cant slip??
Posted 5th Mar 2012 at 21:13
the cams are pinned but the outers can move.
Posted 5th Mar 2012 at 21:19
fatlapit
coolio and always use 136 belt kit yeah
Posted 5th Mar 2012 at 21:22
I prefer to use it yeah, as do most engine builders I know of.
Posted 5th Mar 2012 at 21:37
