Author Subject: Blue smoke! And lots of it!
tommy_306
My rallye has been stood for about 6 weeks and not run at all in that time. Today however, I had to have the car moved off the drive so I could have some stuff moved for me. When it started it kicked out a load of blue smoke. The smoke died down a bit in idle but when it was reved it kicked out even more!
Now is this because it's been sat for so long with out running, or are the rings gone and it's engine rebuild time?
MY RALLYE PROJECT
Posted 5th Mar 2012 at 20:08
swiftyboi006
Its burning oil, could be the rings. Top the oil up to max and see how much the oil burns and how many miles. If after 500 miles or less it burns about 1/4 or more then yes there fooked. Even newer cars burn oil.
Black p3 Love
Posted 5th Mar 2012 at 20:13
could be stem seals or piston rings, leakdown test should confirm.
Posted 5th Mar 2012 at 20:16
tommy_306
Leakdown test, is that the same as a compression test, but you put a bit of oil down into the chambers?
MY RALLYE PROJECT
Posted 5th Mar 2012 at 21:26
heidi6
Sounds like a typical Pug engine to me... LOL
I live work (to pay) for the 306
Phase 3 Astor. Built on Wednesday, 12th April 2000 in France.
Years of 'Creative Maintenance' mean this car is now much lighter and slightly more 'race' specced... Tee hee
Posted 5th Mar 2012 at 23:16
not really, my 205 and zx and 405 hardly use a drop between services.
Posted 5th Mar 2012 at 23:18
heidi6
TBF I think alot depends on driving style. All engines use oil, some more, some less. A mate had an S8 from new and was told to check and top up the oil every 400-500 miles!
Posted 5th Mar 2012 at 23:39
As Meirion says, its either rings or stem seals...Yes
Engines shouldn't really burn oil, both my '6' and my bike don't burn a drop between changes so an engine burning it isn't really acceptable in my opinion as the standard way of life. No
Posted 6th Mar 2012 at 07:10
You sure its oil and its not massively overfuelling due to an electrical issue? Just a thought.
Start it for a short time then take out the plugs and see what they look like.
Posted 6th Mar 2012 at 09:18
tommy_306
Never thought of that! Ill give it ago today and see what results I get!
MY RALLYE PROJECT
Posted 6th Mar 2012 at 11:28
I realise that should be grey smoke, but tbh i've had it with a 205 before when the wiring to the air flow meter went tits up. Looked like oil smoke, but the plugs said fuel.
By the way if it is overfuelling, don't run it for any length and change the oil immediately. You are likely to have the fuel wash the bores and get into the sump. It makes oil completely useless as a lubricant.
Posted 6th Mar 2012 at 13:11
