Author Subject: Fooking washer jets
swiftyboi006
The washer jets dont spray, the pump works as it makes noise. The problem is....i cant get the kents off. Can someone enlighten my stupidity please
Black p3 Love
Posted 9th Mar 2012 at 09:12
sharvey44
pull the pipe off from the jet under the bonnet. check water comes out the pipe.
if so use brute force to remove jet from bonnet. i think you should be able to push them from underneath.
either clean or replace with Xsara mist jets..
Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...
Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? Wink
Currently looking slightly molested due to some c*nt trying to get into it.. Sad
According to the forum Social Worker, because I work in IT, I am socially retarted..
Posted 9th Mar 2012 at 09:49
swiftyboi006
Cheers mate yes the pipes are all clear just the jets must be blocked i have tried to get them off befor but i didnt want to damage the bonnet, ill give it another go with some muscle Thumbs up
Black p3 Love
Posted 9th Mar 2012 at 10:33
shove a 10mm socket over the back of it.
Posted 9th Mar 2012 at 10:42
You can pinch the clips on the sides of the jets on the underside of the bonnet with a pairs of pliers and then pull the jet out from the top. Yes
As stated already, replace with Xsara mist jets, they are much better. Thumbs up
Posted 9th Mar 2012 at 11:19
swiftyboi006
Getting sick of stans help......Thumbs up lol
Black p3 Love
Posted 10th Mar 2012 at 19:45
Just replace, the bas**rds block constantly once you've had trouble wit them once.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Mar 2012 at 08:39
mpieczko
I always find using a small needle often cleans them out a treat.
But as everyone has already said, they are so cheap to replace. Get the Xsara mist jets, they have been brilliant in the time that I have had them.
Posted 11th Mar 2012 at 21:00
mrdeey
Xsara mist jets.. , much much better , get a bull dyke to push the old ones out if you carnt do it!
now new booted , boosted and flying again!
Posted 12th Mar 2012 at 07:12
My front and back blocked and just used a .5mm drill in my hand to unblock
Posted 17th Dec 2016 at 11:27
miki4
Mine were also blocked in my first 306. You could free the jets with a needle (you can aim them with the needle while you're at it) but they would keep getting blocked regularly so I took them out and soaked them in some vinegar to solve any scale, cleaned them and put a small scooter fuel filter in-line.
I cannot tell how durable that solution is as I replaced the washer jets with the xsara ones a month later which have a nice spray pattern that covers most of the windscreen at once. But you should see the s**t inside the filter after five years. However I would not put a fuel filter there again because you get a delay of about one second until water comes out of the jets.
-> XSARA JETS plug and play is the way to go. Thumbs up
Posted 17th Dec 2016 at 12:52
RetroPug
Major thread bump haha.
If you are getting dirt in the system remove the washer bottle and see if it is dirty. When I bought my 306 I was having issues and there was a solid mass of green algae in the bottom inch of the bottle. It was disgusting and all came out in one giant blob.
Posted 17th Dec 2016 at 19:39
sageman
i had a strange white jelly in mine just keped the sprayers on till it all came out (there wasnt much) then a bottle of white vinigar and topped up with water
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 17th Dec 2016 at 20:34
miki4
Maybe a previous owner wanted a baby 306...
Posted 18th Dec 2016 at 00:34
miki4
Did not even notice that. LOL
Posted 18th Dec 2016 at 00:35
