Author Subject: Phase 3 306 1.6 Conversion to 2.0l gti6
Teshboi1988
right heres the crack
i had a 306 1.6. gearbox kinda exploded...
so looking on ebay found a guy who sold me a gti6 engine conversion kit... ecu, loom, gearbox etc...
so then i converted to the gti spec....
suspension brakes exhaust, subframe steering rack etc
whilst i had engine out i thought id wack some wossner pistons in, n do the whole shabang n replace all the bits that wear..
bigends smallends
stem seals..
new gaskets
new crank n cam seals
cambelt
auxbelt
had engine block bored out
had head skimmed
flywheel skimmed
valves lapped
new clutch (proformance)
everything has been cleaned
and serviced it
got ecu programmed to key...
n boom it started...
but.....
its running shit, its idling at 20 then slowly dies n cuts out....
HELP
phase 3 Hatchback V reg 5Door GTi6
Posted 10th Mar 2012 at 09:50
Ok, map sensor or icv maybe?
How are the plugs etc?
Posted 10th Mar 2012 at 10:00
Teshboi1988
also need to know whether the cam pulleys the inlet n outlet are the same? if not how can u tell difference between 2? my guy thinks maybe the cam pulleys where mixed....
Posted 10th Mar 2012 at 10:04
Teshboi1988
how wood i check the sensors?
the plugs are lil sooty
Posted 10th Mar 2012 at 10:05
might help
Posted 10th Mar 2012 at 10:06
Are the plugs not new? Might as well after that trouble no?
Posted 10th Mar 2012 at 10:07
Teshboi1988
looool they are new!!! but from it beening started for bout 20mins checked the plugs and they where slightly sooty cleaned them put em bk runs bit better but still just cuts out
Posted 10th Mar 2012 at 10:09
swiftyboi006
Give the icv a clean Thumbs up
Black p3 Love
Posted 10th Mar 2012 at 15:48
aaron6
If you rev it, is it responsive?
Posted 10th Mar 2012 at 17:37
aaron6
Well done for paying up too. Maybe catch ya at a kent meet one day. Smile
Posted 10th Mar 2012 at 17:39
As said in other thread, what pistons did you have fitted?
Posted 10th Mar 2012 at 19:21
khj100
Locked as there's a parallel thread going on
Posted 10th Mar 2012 at 21:15
This thread has been locked
