what could be wrong??
| Author | Subject: *Help* GTI 6 rear suspension lower on one side ???? |
tom28
Regular Location: Stourport on Severn Registered: 28 Jul 2011 Posts: 253 Status: Offline |
Just discovered after admiring my 6 that the wheel arch gap on the drivers side of the car (ONLY AT THE REAR,) is smaller than the passengers, so much so that it is quite noticeable when each side is compared. what could be wrong?? |
Level ground? e.g flat and not a slight road camber.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
tom28
Yep, actually parked it up on two different spots to make sure i wasn't going crazy, but both were flat surfaces and the gap stayed the same |
darkstar753
Regular Location: Enfield Registered: 12 May 2011 Posts: 241 Status: Offline |
Mine is similar, pretty sure one side has more camber than the other too. Paranoid that its a wonky rear beam (bearing in mind I have no idea what the symptoms of that may be) ________________________________________ Darkstar |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Moved to suspension section! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
tom28
could it be a worn damper?? |
danposs86
Regular Location: Sedbergh Registered: 18 Jun 2011 Posts: 287 Status: Offline |
I came on here to ask the exact same question.Drivers side rear lower than passenger side rear. Hope it is just the shocks. The rear is very soft and bouncy (have adjustable konis, however there isn't much different between settings). ________________________________________ danposs86's GTi-6 |
Rix13
Regular Location: Scarborough Registered: 06 Oct 2011 Posts: 157 Status: Offline |
mines the same, have a very small amount of chamber on passengers side but all drives fine so ive just put up with it.________________________________________ www.eastcoastmodified.orgE46 318i tourer SE - Dog Car/Work horse 306 Gti - Track Project |
tom28
correct me if i'm wrong, but i was under the impression the rear didn't have springs (awaits the inevitable flaming) |
darkstar753
its got torsion bars but still has dampers like any other car, otherwise you would be bouncing all over the place!________________________________________ Darkstar |
tom28
Sweet, so is there anything else that might be at fault apart from worn dampers? (kinda abit relieved now though as other people seem to have experienced/or are experiencing the same problem) How could i go about resolving the issue or is it nothing to worry about |
a torsion bar is a spring, just not a "coil" spring.most likely to be worn trailing arm bearings, a damper would not cause it unless one was seized. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
My 205 was like this, someone had been messing around with the torsion bars before I got it, all sorted now thoug ![]() ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
tom28
Thx everyone for your input |
tom28
oh well looks like another trip to the fooking garage then |
tom28
"most likely to be worn trailing arm bearings, a damper would not cause it unless one was seized"By bearing do you mean BUSH ? |
nope, I mean bearing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tom28
where can i get one from/how much for 1if possible can you do a link to it and post a picture. soz for the persistant demands I want to understand whats wrong so i can fix it |
peugeot ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
