Author Subject: axle stand position
braymond
If I'm jacking the car up using the front jacking point, where is then a safe place to support the car with axle stands?
This is almost certainly a very obvious answer to most, so as long as some useful information comes my way, I'll take the mocking and jeering on the chin
Rallye-R
Nurburgring article
Posted 22nd Mar 2012 at 15:40
i've got about 10 sets of stands so i always play it safe. one under each side of subframe and one under the little eyelets on the chassis
when it's supported as high as possible, i'd put stands back under the jacking points..
Posted 22nd Mar 2012 at 15:45
braymond
Thank you
Rallye-R
Nurburgring article
Posted 22nd Mar 2012 at 15:53
i must admit i usually whack a block of wood under the subframe, trolley jack it as high as possible and then lower onto axle stands as above. saves going round in circles with a jack and whatnot
Posted 22nd Mar 2012 at 17:44
I usually use the two chassis rails under the car, the front part of which is reinforced and double-skinned.
If I jack the rear up, I usually place the stands under the rear axle unless I am working on the axle in which case I will jack on the axle and place the stands on the sill jacking points. Wink
Posted 23rd Mar 2012 at 12:54
ballardpaul
I jack up with the Eyelets on the chassis just till I can get the stands under jacking point.
Nissan 350Z (300 BHP)
Posted 23rd Mar 2012 at 13:17
heliosphan
I use the sill jacking points as infrequently as possible. Witnessing rusty, deformed examples of these areas on previous PSA cars has put me off the idea. Mine are all still fine, incidentally.
I always use the rear part of the front subframe for the business end of the vehicle, and the rear beam for its sweet, sweet arse.
Our S60 has large, dedicated jacking points at each corner. Well done Sweden, 10 points. France, take note.
Alternatively, the floor pans are a good bet. With these, remember to jack up hard and fast (just how she likes it(wheey!)). Don't spread the load with wood. Hoist the car as high as possible and get in and out of it many times.
Posted 23rd Mar 2012 at 19:41
Jacking the front on the sills high enough raises the rear at the same time Thumbs up
I usually go for sub frame for stands as mine seem to fit nicely between the bolts Yes
Posted 23rd Mar 2012 at 19:50
mik
LOL LOL
...especially at the rear where the floor, like most of the other panels, is made of the silver foil out of Gauloise cigarette packets.
Cherry Rallye SOLD
Posted 24th Mar 2012 at 18:25
