cheers
| Author | Subject: bleed screw SORTED |
fatlapit
hi need the lil bleed screw that sits on themostat housing above the sensors.![]() cheers ________________________________________ |
a quid from pug, fitted to most xu and tu engines________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
ty ![]() ________________________________________ |
fatlapit
Pug part no. please?________________________________________ |
I'm sure its an m6 bolt any will do ? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
bigbadbowen wrote: I'm sure its an m6 bolt any will do ? Think it m4 or 5, pretty sure it's. Not m6 however the same applies, just use a bolt of the correct size and thread pitch! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
m6x1, with a hole down the middle and out the side.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
welshpug! wrote: m6x1, with a hole down the middle and out the side. Fair enough, I stand corrected! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
np ![]() I have run with a SS socket headed capscrew when I snapped one and didn't have a spare to hand, proper screw makes it a lot easier. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
