Author Subject: URGENT - High boost spark plugs
chrisd306
Need to know what plugs it is for my high boost 306, so i can get the right ones ive only got like half hour!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 24th Mar 2012 at 12:18
high boost spec sheet just says
NGK Irridium Spark Plugs [high boost heat grade] £35.00
Posted 24th Mar 2012 at 12:22
chrisd306
sure i have 7's but its 8's i need
& Audi Q5 S Line
Posted 24th Mar 2012 at 12:23
rallyeash
i run BPR8ES
309 3dr K20 Type R
Posted 24th Mar 2012 at 13:00
birk
I'd go for 8s
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
chrisd306
couldnt sort any out before 2m, sor5ted some s3econd hand ones same as what was in tho so should be fine
& Audi Q5 S Line
Posted 24th Mar 2012 at 16:36
You will indeed be needing 8's for the high boost. Yes
Posted 24th Mar 2012 at 19:09
chrisd306
In a Saturday afternoon not possible, will get some new ones Monday
& Audi Q5 S Line
Posted 24th Mar 2012 at 19:15
mabgti
NV motors
7's will be fine.. but 8's preffered
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 25th Mar 2012 at 22:08
Not sure I agree 7's will be fine Mabz, Birk killed 3 supercharged engines because he was running plugs which were too hot. Deffo 8's as that is what it has been mapped for and anything hotter is just to risky IMO. Yes
Posted 25th Mar 2012 at 23:05
Rich E Forum Admin
Birk was running standard plugs though. The low boosts run fine all day long on 7s and if anything it's more important on those.
http://www.306gti6.com/forum/showthread.php?id=128248
That said, no-one seems to have had any problems with the 8s coking up when using S/C engines in less extreme situations (but then who pootles about in an S/C 306?!)
Posted 26th Mar 2012 at 00:35
