Author Subject: whats this lead
az6556
hi i have just got my first car about a month ago a gti6 and been having problems with it cutting out only on damp mornings so changed spark plugs today and noticed this lead was not connected to anything could this be causing me problems. if not any ideas on the issue thanks aaron
IMG_0102.JPG.zip
Posted 1st Apr 2012 at 18:30
az6556
image not working its connected to the MAP lead also the map does not have the white part on it that is in the sensor location pic i found on this site what does the white bit on top of the map sensor do.
Posted 1st Apr 2012 at 18:32
Become a member or feck off
Then I shall tell you
By the way the car stalling has nothing to do with map sensor Yes
Posted 1st Apr 2012 at 18:59
SteviePut
It's likely to be for the other type of map sensor used on some cars. It's not needed so don't worry. Clean your ICV. If it still doesn't work just change the fecking thing! They're a pain in the arse.
Posted 1st Apr 2012 at 19:02
mechanical_repairs
Are you quite sure?
Carl
Posted 1st Apr 2012 at 19:06
just a spare plug.
Posted 1st Apr 2012 at 19:09
az6556
ok thanks is still likely to the icv even if it is only on cold damp moorings when i first start it up if it is anyone know a good place to get a replacement.
Posted 1st Apr 2012 at 19:12
Are you quite sure?
Carl
Not 100% but usually the Icv is the problem ? But it could be anything I guess
Posted 1st Apr 2012 at 19:23
justinaccurate
All in good time Razz
Posted 1st Apr 2012 at 20:42
