Author Subject: phase 3 radiator
jonv
as above - decent 2nd hand one would be great.
2000 'W' GTi-6
Posted 2nd Apr 2012 at 16:32
any 6 radiator should fit but you need to know what you bottom hose connection is? there are 2!
and if your gona get another radiator i'd get a nissens one like this one!
Ebay one £125 all in
in all honesty mate a radiator isnt something you want to skimp on!
that goes and you can Wave bye to your head gasket!
Smile
Posted 2nd Apr 2012 at 16:39
snjbowk
i got a minter off a 1999 6.£50 posted
breaking moonstone v plate 6!!!
Posted 2nd Apr 2012 at 22:29
jonv
thanks for that - i think a new one would be sufficient - is there an easy way of seeing which connector i have without getting under the car?
Smile
2000 'W' GTi-6
Posted 3rd Apr 2012 at 12:01
from mid phase2 they were the metal clip type, if you are unsure just buy a new bottom hose for about £22+vat, comes with new o-ring.
the linky is for the very early type.
you want this type
http://www.ebay.co.uk/itm/NISSENS-Radiator-PEUGEOT-306-2-0-GTI-XU10J4RS-96-97-/310334733525?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4841643cd5
Posted 3rd Apr 2012 at 12:03
few small tips!
if you go for the later push in type with a retaining clip use some silicon sealant around the metal bathroom silicone from wilco should suffice, before pushing it in it makes for a much better seal!
and gently roll the pipe in mini circles as you massage it in to stop the O-Ring from twisting and not creating a good enough seal!
and to fit it's much easier if you remove the headlight/grille/Slam panel,.. Wink
Posted 3rd Apr 2012 at 15:32
no need for any sealant, just a new o-ring.
bathroom stuff is probably the worst stuff to use too.
Posted 3rd Apr 2012 at 15:54
don't see why? Dunno let it set! it just aids the seal a little better doesn't it?
I got new O-Ring went in fine,. eventually LOL dripped like a mo-fo!
used sealant Job Jobbed! not a problem since!
Posted 3rd Apr 2012 at 16:35
jonv
at the risk of sounding thick - it has 93-96 on that one - mine is a 2000
they compatible?
Smile
2000 'W' GTi-6
Posted 4th Apr 2012 at 12:46
I'd just do as WP suggested. Buy a new pipe and do them together.
For the price of the pipe it's good piece of mind that it will seal well.
  • Posted 4th Apr 2012 at 12:58
    fatlapit
    unless i`m a mong i have always needed a dab of silicone too
    Posted 5th Apr 2012 at 08:56
    Shut up
    Posted 5th Apr 2012 at 09:20
    T400 PUG Banned!
    ive got a nearly new nissens rad which is in very good condition but ive poked four holes through the fins to mount a slimline fan to it. Makes no operational difference just might look alarming. £75 posted. plus i have a nearly new pug bottom hose to go with it if you want £10 so £85 all in.
    Ive only ever used a bit of moly grease on the bottom joint as it gets rusted shut otherwise which makes removing an old rad a total b**ch without cutting bottom hose off.
    Posted 5th Apr 2012 at 16:00
    mjm3043
    I have a nissens. Along with a good bottom hose, will do it all in for £70 delivered.
    Posted 5th Apr 2012 at 20:03
