Author Subject: "fluff" at fast idle between 2- 2.5k rpm
sampsonm
There is no misfire & revs remain steady, applying throttle there is no hesitation the pick is clean & powerful, (just luv the torque of these engines- lovely) there is no loss of power right through rev range. The issue appears to clear after a long high speed run.
Engine parameters are very good for a engine that has 123k behind it and are @2500:
lamda 1.006, HC 0, CO 0.026
Occasionally a "lumpy" idle @ 850
If this was a carburated engine I would have said fuel starvation as most likely culprit.
Posted 9th Apr 2012 at 11:52
what are the values at idle?
Posted 9th Apr 2012 at 14:43
sampsonm
CO only recorded @ 0.005%
Posted 10th Apr 2012 at 19:57
