Author Subject: Air scoop and passenger driveshaft
atterz
As title, i need the standard air scoop for a rallye/6 so i can sort some kind of enclosed induction setup. And a drivershaft because its started clunking as i pull of since i put the solidish gearbox mount on so im assuming that may be the issue.
Cheers!
owain wrote:
Posted 12th Apr 2012 at 15:03
get a snorkel off someone breaking a 6/ rallye cheep enough!,..
and I'd thoroughly investigate before buying drive shafts etc,..
have you checked your engine's top mount etc?
Posted 12th Apr 2012 at 15:13
atterz
I havent checked the top mount cradle yet, will do this afternoon if the rain f**ks off! Its ever since i put the really stiff gearbox mount on, it wasnt there at first but it now knocks as i move off.
Posted 12th Apr 2012 at 15:16
snjbowk
£10 posted for the air scoop?
breaking moonstone v plate 6!!!
Posted 12th Apr 2012 at 18:54
2 part Air scoop £8 posted.
  • Posted 12th Apr 2012 at 18:56
    Could be the bottom mount is loose on the engine. The top mount cradle has never been welded by the way, but then it never needed it!
    Posted 12th Apr 2012 at 19:33
    atterz
    Good point Adam! I didnt think it had been welded and when i got it it felt loose, i didnt remove the top mount but screwed it back in and it went tight again. Best get her welded and that bottom mount replaced!
    Posted 12th Apr 2012 at 21:16
    Dunno what top mount is in there now. I sold it with a new baker group n one.
    Posted 12th Apr 2012 at 22:18
    atterz
    Most certainly not in there now mate and its only changed hands the once between me and you! Ill rip it off tommorrow and fingers crossed the cheap pattern part mount has failed and not the cradle!
    Posted 12th Apr 2012 at 22:37
    If need driveshaft think I have one.
    Posted 13th Apr 2012 at 00:15
