Author Subject: Help! Major electrical issues.
anderoo
I'm trying to diagnose a major issue with my brothers car.
It occasionally wont start but when it does it will idle fine.
The symptoms start when you drive away. Under full throttle the car seems fine until you let off. Driving normally and after backing off the car will cut out randomly, revs will slowly die similar to lambda issues. While this is happening both the rev counter and speedometer bounce around like crazy. The car sounds very rough and smells rich. It will also cut out and stall when pulling up to junctions.
So far I've tried changing the ECU, the relay behind the ECU, the cam and crank sensors and the lambda. I've also checked the voltage on pin 35 of the ECU which has battery voltage even while it's cutting out so it seems power to the ECU is fine.
Any suggestions as to where I should be looking next?
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 14th Apr 2012 at 13:15
Give the ICV a clean
  • Posted 14th Apr 2012 at 13:16
    Or replace it.
    Posted 14th Apr 2012 at 13:20
    anderoo
    ICV might be a shout for the stalling, going to change it later today, however I can't see it causing all the other major issues.
    Pics of my 6
    Earth cables all ok?
  • Posted 14th Apr 2012 at 13:21
    wilyoldave
    MAP sensor?
    No more peugeots Sad
    Snap - no more RS clioSad
    Now Ph1 RS clio Smile
    Posted 14th Apr 2012 at 13:22
    aphyx
    Tried the ICV from Roo's 6 and it made no difference, have put a direct earth from the battery to the body to bypass any faulty earths. Haven't got another MAP sensor to try but I think that might be the next thing to test.
    Read the Ecu with a fault code reader and received this fault
    Unable to find any clue of what this code means
    Thanks for the ideas
    Onward to the Edge!
    Posted 14th Apr 2012 at 15:16
    is that a generic OBDII reader? no use on a 306.
    Posted 14th Apr 2012 at 15:31
    wilyoldave
    Which Map sensor do you need ?
    Posted 14th Apr 2012 at 15:33
    anderoo
    The reader can read and clear codes from the MM1AP ecu fine. I've used it to pick up lambda/map sensor faults before. Unfortunately the error that its showing here isn't a generic code and I can't find any trace of it on the net...
    Pics of my 6
    Posted 14th Apr 2012 at 22:10
    anderoo
    It's the older type, mine is on the newer type unfortunately so it's one of the few things we can't just swap. It seems likely that it's more than just a sensor though, none of the sensors would cause the dials to go haywire surely??
    Pics of my 6
    Posted 14th Apr 2012 at 22:11
    mabgti
    NV motors
    Get it on peugeot planet!
    Team Supercharged Gti-6
    NV Motorsport
    Automotive Performance Tuning
    0121 448 7515
    ECU Remapping/ DPF removal
    www.nvmotorsport.com
    Facebook Page
    Project S6
    Posted 14th Apr 2012 at 22:52
    wilyoldave
    this one?
    I have one as I bought it in error.
    Give me a shout if you want it.
    Posted 14th Apr 2012 at 22:55
    anderoo
    Don't know anyone local with it. Sad
    wilyoldave wrote:
    this one?
    Will do. Thumbs up
    Pics of my 6
    Posted 15th Apr 2012 at 00:33
    Unplug power steering sensor bud it's down the front of the engine ? Sounds silly but causes all sorts of running issues when faulty ?
    Posted 15th Apr 2012 at 00:51
    smegal
    Check your battery earths Thumbs up!
    Ex SC-6
    Now in a Megane R26
    Posted 15th Apr 2012 at 19:38
