| Author | Subject: Clutch cable replacement problems... |
thewho07
Regular Location: Scotland Registered: 11 Aug 2009 Posts: 289 Status: Offline |
Been following the guides in the FAQ section. Got the old cable ready to come out, string attatched, air con pipes pulled up, but it wont budge! Trying to pull it from different angles etc isnt working either! Any ideas?Cheers |
Weetabix________________________________________ ![]() |
thewho07
Haha i'll try that! Broken foot doest make it easier either... |
rikky
edit> what won't budge? the pipes?it's probably getting trapped under the servo on the big black grommet. i just wiggled it from the bottom whilst a mate pulled it in. didn't take very long. we just undid the aircon pipe securing clip and prized the pipes up a little bit using a massive crowbar ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
smegal
Lube it up with fairy liquid!________________________________________ Ex SC-6Now in a Megane R26 |
thewho07
Right. Got the new one in, nearly. Its lined up ready to get pulled through the hole. Been at it for ages and cant get it through! Ahhhh! I'll try again tomorrow. Got enough cuts on my hands for one day. Haha |
stan_306gti6
thewho07 wrote: Right. Got the new one in, nearly. Its lined up ready to get pulled through the hole. Been at it for ages and cant get it through! Ahhhh! I'll try again tomorrow. Got enough cuts on my hands for one day. Haha The first time you do one of these they are a nightmare as you are discovering... Once you've done 2 or 3 they become a doddle as you know exactly what to do. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
thewho07
Finally done it. Hope i never have to do that again! Haha. Worth it though, clutch is twice as easy to use now. |
stan_306gti6
Well done, as I say the first time has been difficult but if you do ever need to do it again you will find it easier and know how to do it. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
thewho07
Clutch is much easier to use but...I am struggling to select gears now. Reverse, 1st and 2nd are really hard to get. The others aren't too bad. Take it the clutch is on its way out?? |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
thewho07 wrote: Clutch is much easier to use but... I am struggling to select gears now. Reverse, 1st and 2nd are really hard to get. The others aren't too bad. Take it the clutch is on its way out?? yeah could be your clutch plate,... that's another fun job to do! Stan helped me do mine i'll never forget that day! ![]() best was when Stan decided that Jokers head could be taken off with the Exhaust manifold still attached,..(seperate job same day!) and it ended up with my arms sitting in between the head and the block to stop the valves touching anything,.. while stan frantically tried to undo the bolts from the manifold from underneath think joker was running around flapping his arms in the air or something? happy days ![]() but yeah if your going to do a new clutch defo get some help from someone that knows what their doing,.. ________________________________________ Proud Member of the ASTOR Owners Club |
thewho07
How much can I get a clutch kit for? Anything else worth replacing at the same time? |
gnrlee
peobably get this one for £50?,. Clicky there are some seals that you could replace at the same time while it's off! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
thewho07 wrote: How much can I get a clutch kit for? Anything else worth replacing at the same time? Clutch release arm bushes,crank seal might need doing,drive shaft seals. I got a service exchange Valeo clutch kit from Pug for just over £80 ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
