A red rallye in progress!
displaying posts 1 to 25 of 28
| Author | Subject: engine tapping |
barnettjd77
Regular Location: dorchester Registered: 12 Nov 2011 Posts: 483 Status: Offline |
This is the second gti-6 i have owned that taps from time to time, just wondering if the oil additive is complete bollo**s or does it actually make a difference? thanks.________________________________________ A red rallye in progress! |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
They all have a random tap every now and then but if its happening everytime you thrash it then your oil could be to hot or not enough oil pressure.Not tried additives tbh. ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
barnettjd77
Ah right, well sometimes when it's cold but then stops after couple minutes.. how can i tell or sort oil pressure?________________________________________ A red rallye in progress! |
aaron6
Mine does this. Just a worn lifter. Would'nt bother worrying about it. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
barnettjd77
aaron6 wrote: Mine does this. Just a worn lifter. Would'nt bother worrying about it. ![]() I won't bother then though i ecpect a oil change/service for whole car wouldn't go a miss right now, and the cambelt ________________________________________ A red rallye in progress! |
aaron6
Mine getter tappier when nearing an oil change, lets you know when to do it though which is nice... ![]() Should get quieter with fresh oil. Only use a genuine pug filter though as they have a non return valve in. Don't let the cambelt snap our slip either our else you will have a permanant tapper... ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
barnettjd77
Yeah they can be helpful mine is due very soon I reckon. Ah I see it's not a genuine filter on now, so will have to order one up ![]() ________________________________________ A red rallye in progress! |
aaron6
Might sort out your tap to a degree as the oil won't drain out the filter giving the pump more to circulate. ![]() Keep us posted what happens on oil change with genuine filter. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
aaron6 wrote: Might sort out your tap to a degree as the oil won't drain out the filter giving the pump more to circulate. ![]() Keep us posted what happens on oil change with genuine filter. ![]() Its not so much that the pump has more to circulate but the fact that there is oil stored in a higher location which can make its way to the head much quicker. If you have lazy tappets the hydraulic lifter treatments are very good. Just make sure you put it in just before an oil change so that once it has done its job you can change the oil and filter for new and hopefully have no more problems. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
I stand erected... Cheers lover... ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6 wrote: aaron6 wrote: Might sort out your tap to a degree as the oil won't drain out the filter giving the pump more to circulate. ![]() Keep us posted what happens on oil change with genuine filter. ![]() Its not so much that the pump has more to circulate but the fact that there is oil stored in a higher location which can make its way to the head much quicker. If you have lazy tappets the hydraulic lifter treatments are very good. Just make sure you put it in just before an oil change so that once it has done its job you can change the oil and filter for new and hopefully have no more problems. Would you suggest something like Wynn's? Or is there a preffered brand? ________________________________________ ![]() |
aaron6
I used wynns in my old one. Worked okay like. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
aaron6
Just a quicky, it may also be worth looking to see if a plug is tad loose, had this a few months ago, it caused me an intermittent tap. Albeit, after a couple of weeks it developed into what sounded like a genuine tapper. Its free and thus worth a look.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Good point about loose plugs Aaron. ![]() I normally use Wynns products and they seem to be of high quality. I would recommend them. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: I normally use Wynns products and they seem to be of high quality. I would recommend them. ![]() Wynner! ________________________________________ ![]() |
stan_306gti6
dangti6 wrote: Wynner! ![]() Nice pun. You're welcome mate. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
barnettjd77
Ah right i shall have a look at plugs first off then. You mean get some wynns and chuck it in the old oil before i change filter ect? i shall keep you posted on how it goes ![]() ________________________________________ A red rallye in progress! |
aaron6
Yeah mate, check the plugs. If all are tight bung in some wynns and yes, keep us posted on this thread mate. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
barnettjd77 wrote: Ah right i shall have a look at plugs first off then. You mean get some wynns and chuck it in the old oil before i change filter ect? i shall keep you posted on how it goes ![]() Exactly that. Put it the old oil first and then run the engine for about 30 mins at 3000rpm I believe it is (will state exact figures in the instructions) and then drain oil, change filter and refill with new oil. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Usually the plug closest to the cambelt.I'd also use Total Quartz 9000 fully synth from Peugeot instead of a semi synth as original. Mine always seemed to run better on it - was recommended by Mr Chambers ![]() Also can be pretty cheap if you buy it in 20L tubs - £40 odd iirc ________________________________________ Nothing to see here |
barnettjd77
Cheers stan shall have a look at it when it stops pis*ing it down, bloody car is more hastle than it is worth atm And shall look into get 20L tub of it then as i tend to get through some! ________________________________________ A red rallye in progress! |
Speak to Warners Peugeot in Tewkesbury about the tub, if they don't deliver then try to get your local Peugeot place to price match. Or have a look on Opie Oils as they often have good deals. ________________________________________ Nothing to see here |
barnettjd77
I shall do cheers adam I have checked the plugs and they are resonably tight though the second one in from the cambelt side was a tad loose if that would make any difference? ![]() ________________________________________ A red rallye in progress! |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
barnettjd77 wrote: I shall do cheers adam I have checked the plugs and they are resonably tight though the second one in from the cambelt side was a tad loose if that would make any difference? ![]() i'll just be a sticky lifter! mine used to give light taps every so often,.. in the engine rebuild last year Pugjim squeezed the crap out of them iirc and made them like new again! ![]() of cause the 1st time they were used again they sounded like a bag of s**te I think the look on my face said it all when jim reassured me they were going to be noisy and that was normal until they filled up with oil again ![]() you'd know if you have a taper it sounds like a sewing machine :/ ________________________________________ Proud Member of the ASTOR Owners Club |
barnettjd77
Oh right it is bloody annoying though ha,I for sure am not gonna think about getting it rebuilt only just started to tart it up.. clean things and paint covers ect I use to have a blaze 6 and that was constantly tapping.. until i tapped it into a telegraph pole ![]() ________________________________________ A red rallye in progress! |
