I have trawled down through the gearbox parts list on Servicebox but can't find a diagram mentioning these.
| Author | Subject: Clutch fork bushes |
Where are these listed in servicebox?I have trawled down through the gearbox parts list on Servicebox but can't find a diagram mentioning these. ________________________________________ ![]() |
Ah ha found it in the clutch section.Numbers for future searches: Top: 2175 21 Bottom: 2175 20 ________________________________________ ![]() |
look for the newer design, might now show on a vin search, they are cheaper and have a seal i think________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I haven't got the VIN on me and need to order it ready to arrive Friday to do over the weekend.They pulled my car up from the Reg which they haven't done with ph2 registration numbers before, so may be able to do it. I am expecting to have to order 2 of each. That's what I had to do with the yellow ones last time. ________________________________________ ![]() |
2175 21 FORK BEARING SUP BA- - WHITE - UNTIL RPO 08484 2175 55 SUP - SINCE RPO 08485 2175 20 FORK BEARING INF BA- - WHITE- UNTIL RPO 08484 2175 54 INF - SINCE RPO 08485 2175 56 PROTECTOR 20,4X25,9-11 - SINCE RPO 08485 parts 2175 55, 54 and 56 are 74p, 74p, 39p! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Blimey, That's a difference. I think one was ~£2ea and the other ~£2.70ea approx.I rang the dealer earlier and they actually have 2175 20 and 2175 21 on the shelf so I can collect this evening. I will ask if they have the others on the shelf. I doubt it, but even if I have to order 2 like I did with yellow ones in the past, still makes it cheaper and presumably they are a better product. Thanks for those RE: 2175 56 PROTECTOR 20,4X25,9-11 - SINCE RPO 08485 What is this one exactly, is it a replacement seal for the 2 newer bushes? Or is one of those needed for each of the bushes because they don't come with them? ________________________________________ ![]() |
it looks to be a seal for the later type bushes, only one is required, I haven't taken apart any later cars than that date so don't know exactly what they look like but it would appear to address the issue in that water gets in and rusts the shaft which accelerates wear and stiffness in the bushes________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
The later bushes in question would appear on cars built after 01.02.2000 according to the guy at the parts desk this afternoon.I paid over the odds for the older ones purely as they were in stock so I only had to buy the 2 I needed rather than a pack of 4. ________________________________________ ![]() |
stan_306gti6
dangti6 wrote: The later bushes in question would appear on cars built after 01.02.2000 according to the guy at the parts desk this afternoon. I paid over the odds for the older ones purely as they were in stock so I only had to buy the 2 I needed rather than a pack of 4. As my car was built on 17/09/2000 that means that originally it should have had the newer type bushes then... ![]() I don't remember them being any different to any others I've seen to be honest... ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
I'm only going on what he told me Stan. He got a book out which listed all the build codes, and looked at the 'SINCE RPO 08485' date and it was listed as the 1st Feb 2000.You could have replacement bushes, or the info I was given was wrong. I know which i'd be putting money on ![]() ________________________________________ ![]() |
stan_306gti6
dangti6 wrote: I'm only going on what he told me Stan. He got a book out which listed all the build codes, and looked at the 'SINCE RPO 08485' date and it was listed as the 1st Feb 2000. You could have replacement bushes, or the info I was given was wrong. I know which i'd be putting money on ![]() Come to think of it, it wasn't me who removed the original box. ![]() The box I have now has the 'older' style bushes but then it is from a 1999 car originally. ![]() Ignore me, as you were gentlemen... ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
I am some what confused on these codes as i dont know even where to begin on service box.I have a w reg gti 6 and will need to do these bushes soon. Do i need the newer ones?? and if so is it just the 2 bushes for the for arm or do i need anything else?? i.e protector seals etc?? Any chance you could list the part name with the code for thicko's like me who dont understand all these rpo codes etc. Thank you . ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
If you go in with your VIN, they will tell you which ones you need.Due to the uncertainty of whether they are much of an improvement, I would just use the 'general' white plastic ones. ________________________________________ ![]() |
ive got some i no longer need.£5 posted any good to anyone? |
dangti6 wrote: If you go in with your VIN, they will tell you which ones you need. Due to the uncertainty of whether they are much of an improvement, I would just use the 'general' white plastic ones. What if you have a replacement box and you don't know the vin it was originally built with? ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
As Dan said Andy, just go with the normal replacements. As long as the shaft is clean and you put some grease in the bushes it will be fine. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
clen666
stan_306gti6 wrote: As long as the shaft is clean and you put some grease in the bushes it will be fine. Ooh err ________________________________________ Team 'unintentional rat look' |
stan_306gti6
clen666 wrote: stan_306gti6 wrote: As long as the shaft is clean and you put some grease in the bushes it will be fine. Ooh err ![]() Nothing like a clean shaft eh... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
And don't use copper grease ![]() ________________________________________ ![]() |
So basically give my shaft a good clean and then make sure I lube it up.........________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Yeah. The same prevention technique you use to extend the life of that banjo string.________________________________________ ![]() |
But I'm Jewish ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
