Author Subject: ph1 xsara vts ECU
Obeast
my question is, and i may get the hell ripped outta me if this is a dumb question, but are the ECU's from the gti-6 and xsara vts ph1 the same/ compatible? Ive been informed my ecu is ill and is causing problems with the stepper motor functioning properly, causing the annoying stalling im getting. I have been quoted 300 quid to have it tested and reprogrammed.
Thanks
My car has 120kg of ballast- Me!
Posted 21st Apr 2012 at 20:36
yup.
Posted 21st Apr 2012 at 20:44
Obeast
my xsaras an S reg, which phase pug ecu would i need, because i think there is one for sale at the minute on here.
Posted 21st Apr 2012 at 20:47
An S reg '6' would be a Phase 2 so you're best off looking for one of that age. Wink
Posted 22nd Apr 2012 at 17:47
peetypug
Any as long as it's a 1ap 10 will be fine
I've currently got a phase 1 ecu in my phase 2.5 rallye
Just make sure when you plug the new one in (unless it's a professionally unlocked one) that your ignition is on! I go fully on (bar the cranking point) when I do it
otherwise you'll just lock it Sad
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 22nd Apr 2012 at 19:42
doesnt matter where your ignition is when you fit, only when you remove.
Posted 22nd Apr 2012 at 19:45
peetypug
You sure??
That's the way I do it, as I'm sure I was told that on drivers Dunno
Posted 22nd Apr 2012 at 19:48
ryangti6
I don't think it matters where it is when you refit but if you have an "open" Ecu not a "unlocked" one I have been told that if you don't disconnect the immobilser wiring on the car you are refiiting it to the Ecu will re lock so maybe the way you have been told prevents this happening.
To the original poster I would advise you get a second opinion on the diagnosis as there are lots of things that stop gti6's and Vts's idlling properly but I'm yet to come across one where the Ecu has been the cause.
Ryan
Posted 23rd Apr 2012 at 20:45
scotzman
Have you tried an ICV clean and an ECU reset?
Posted 23rd Apr 2012 at 20:52
peetypug
sounds about right
but as the ecu isnt actually coded to the car this is the way round it if you are keeping the 306 imobiliser (all the imobiliser does is send a 12v signal to the ecu)
if its for a conversion in a 205 for example you only need an open ecu
Posted 23rd Apr 2012 at 23:03
Obeast
Had a brand Icv fitted in august, as for ECU reset is it as straight forward as the battery being disconnected over nite?
As for the diag it was the deepest any body had managed to get, no other tests came up with anything as thorough.
Thanks for all the info so far guys.
Posted 24th Apr 2012 at 18:10
ECU reset can be carried out by leaving the battery disconnected for over 20 mins. Then reconnect it. Wink
Posted 24th Apr 2012 at 22:51
Obeast
In that case i must have reset it 3 times already lol, and still the problem persists! I cant keep chucking money at it now my circumstances have changed, i may have to seriously consider gettin rid of it Sad
Posted 25th Apr 2012 at 06:51
