Author Subject: pic's of harness mounting points
7057sam
Hi guys soon to be fitting 3 point harness,just need some advice of mounts points for them thanks
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 22nd Apr 2012 at 19:03
one to the tunnel, one to the sills, rears to the harness bar on the cage and the middle one straight down to an eyelet fixed to the floor.
Posted 22nd Apr 2012 at 19:05
chris with a pug
what he said.
You can use the bolt hole that the bracket that holds the belt on the seal. Then mark the rest up from that.
Posted 22nd Apr 2012 at 19:19
7057sam
So no chance of using the seat belt harness points ?
Rallye dead Sad
Posted 22nd Apr 2012 at 19:55
stu
You mean the seat belt mounting points in the rear?
You can use them, but expect a crushed spine if you're ever unfortunate enough to crash.......
Posted 22nd Apr 2012 at 20:10
7057sam
No i was thinking of the points on the floor near the base mount
Rallye dead Sad
Posted 22nd Apr 2012 at 20:54
eddy_gti6
I have used the rears seat belt mount next to the window
Posted 22nd Apr 2012 at 20:57
eddy_gti6
Posted 22nd Apr 2012 at 21:00
chris with a pug
that is where mine are.
Posted 22nd Apr 2012 at 21:04
Too low, your shoulder straps want to be as close to horizontal as you can get them.
Posted 23rd Apr 2012 at 08:43
Chris's one's there look pretty spot on Smile
Posted 23rd Apr 2012 at 09:04
