Meirion will probably be able to confirm though.
"Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6
2000 (X), Moonstone
| Author | Subject: 195 BHP STANDARD ENGINE |
stan_306gti6
Post #126
I would of thought so Dan, Kent certainly do. ![]() Meirion will probably be able to confirm though. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #127
On the end of the shaft I expect. Would be better if they were marked along them, but just means I have to commit to removing to find out, unless I can measure the lobes with a vernier and check those measurements with Cat Cams to find out what they are exactly.________________________________________ ![]() |
dav1
Regular Location: leek/staffs Registered: 20 Jun 2011 Posts: 312 Status: Offline |
Post #128
Is there any rr days coming up were bob can bring his motor an stick it on the rollers?________________________________________ 230bhp 205 gti6 |
dav1
Post #129
quote: Wind your neck in The Goodwood in question was just a shonky conversion,that the owner had paid a supposed prefessional company to do. I looked at it and it looked like a DIY pretty rough conversion. The engine was fitted onto the original 309 engine mounts,he was told by pug1off they would be fine. Would you do a conversion like that and drop it on them? No,exactly. I put my engine in on the standard mounts yes. As long as they in good condition they will be perfectly fine. This does't mean pug1off should Guarantee them does it? Think you mean professional. So you wind your neck in pal . ________________________________________ 230bhp 205 gti6 |
Post #130
dav1 wrote: quote: Wind your neck in The Goodwood in question was just a shonky conversion,that the owner had paid a supposed prefessional company to do. I looked at it and it looked like a DIY pretty rough conversion. The engine was fitted onto the original 309 engine mounts,he was told by pug1off they would be fine. Would you do a conversion like that and drop it on them? No,exactly. I put my engine in on the standard mounts yes. As long as they in good condition they will be perfectly fine. This does't mean pug1off should Guarantee them does it? Think you mean professional. So you wind your neck in pal . So you cut corners too Whats the point of using old used mounts when its so easy/cheap to fit new ones? Then again your obviously happy with doing a half arsed job.............. Keep on bodging ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
dav1
Post #131
Ok I see Wat your saying. Every time an engine is re-moved an re-placed you must put new engine mounts in. Cheers ________________________________________ 230bhp 205 gti6 |
Post #132
dav1 wrote: Ok I see Wat your saying. Every time an engine is re-moved an re-placed you must put new engine mounts in. Cheers No you knob,everytime you fit a bigger/heavier/more powerfull engine to a 20 year old car they should though Some people should not be allowed to work on cars................ ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
dav1
Post #133
Listen dickhead, so no ones changed the mounts before hand? You no nothing about that guys car. yo just strolled over an thought you new it all. pug1off got more than you got so they must be doing some thin wright. ________________________________________ 230bhp 205 gti6 |
Post #134
Please come back TC, all is forgiven^^________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #135
stan_306gti6 wrote: I would of thought so Dan, Kent certainly do. ![]() Meirion will probably be able to confirm though. I've not seen any Catcams out of the engine but would imagine they'd be marked in the same place as my Piper and Newmans cams, on the end where the pulley goes. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #136
dav1 wrote: Listen dickhead, so no ones changed the mounts before hand? You no nothing about that guys car. yo just strolled over an thought you new it all. pug1off got more than you got so they must be doing some thin wright. How many spelling mistakes clever dick?????? I know what the owner told/showed me thanks pug1off got more what than me? I know your all in-bred around Staffs,but you really are a good advert for the area ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
fatlapit
Post #137
same mounts i believe________________________________________ |
maddriver9
Regular Location: nr leek Registered: 12 Mar 2008 Posts: 341 Status: Offline |
Post #138
coskev u pleb, get ur self down to staffs so us "inbreads" can slap you all over.dickhead ! ________________________________________ 178bhp 205gti6¼ mile in 14.2 |
Post #139
![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #140
maddriver9 wrote: coskev u pleb, get ur self down to staffs so us "inbreads" can slap you all over. dickhead ! ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Post #141
![]() ..and just like that, the old forum is back ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
Post #142
cjm_harris wrote: ![]() ..and just like that, the old forum is back ![]() Ohhhh I do love it on here ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
stan_306gti6
Post #143
I love how a thread about a 'standard' engine making 195bhp turns into a slapping contest... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
miles
Post #144
I've had a GTi6 engine on Webber 45 DCOE Carb's on a unknown RR |(To me) and as we know unless the engine has been on a proper dyno then figures can be out, But the engine made 175bhp (Flywheel) which is the same as a couple of Bodied GTi6 engine's I know of done on another RR but until I stick a std 6 engine on them I have no reference to what it's like ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
stan_306gti6
Post #145
cjm_harris wrote: Have you had your ECU reprogrammed to reflect the changes? He's running carbs, so no need for ECU management... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #146
stan_306gti6 wrote: cjm_harris wrote: Have you had your ECU reprogrammed to reflect the changes? He's running carbs, so no need for ECU management... ![]() I did put in my post I dont know much about engines didnt I? ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
stan_306gti6
Post #147
No worries Chris, its about the only part of his spec he's actually told us about...The rest of it is secret squirrel...hush hush. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rallyeash
Post #148
Paintented next!________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
atterz
Seasoned Pro Location: Stafford Registered: 18 Feb 2011 Posts: 1,134 Status: Offline |
Post #149
coskev wrote: dav1 wrote: Listen dickhead, so no ones changed the mounts before hand? You no nothing about that guys car. yo just strolled over an thought you new it all. pug1off got more than you got so they must be doing some thin wright. How many spelling mistakes clever dick?????? I know what the owner told/showed me thanks pug1off got more what than me? I know your all in-bred around Staffs,but you really are a good advert for the area Bloody hell me, we arent all inbred around here . Wait i was born in Germany....________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
atterz
Post #150
Im interested in the actual engine that Pug1off claim to make this power. I too want to simply cam it for the time being before considering a supercharger, i mean RussianGuys car goes incredibly well! And Braymond has done the same. Id rather not be taking the head off though....________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
