Author Subject: burning oil after doing head gasket
weemangti
my head gasket went was using loads of water and missing so done my headgasket sent the head away had it skimed and pressure tested and new valve stem oil seals put in put it all back together now after its been on idle when you pull away or rev it, it blue smokes like nakered valve stem oil seals and if you drive it hard it will miss higher up the rev range then drop a cylinder like its fouling the plug
any ideas
thanks adam
Posted 30th Apr 2012 at 18:32
fatlapit
oil seals rip it apart again and start again
Posted 30th Apr 2012 at 18:37
fatlapit
or blocked breathers
Posted 30th Apr 2012 at 18:38
Valve stem oil seals...Yes
There are two types, one set for a 5mm valve stem and one set for a 6mm valve stem.
I wonder if someone has put 6mm seals on 5mm stems? Dunno
Posted 30th Apr 2012 at 18:55
Could be worn valve guides tooWink
Did they check them?
The head I had rebuilt needed 8 new exhaust valve guides,just through age/wear,not a snapper headSmile
Posted 30th Apr 2012 at 19:00
weemangti
thanks for all the input guys the head was all checked by the engineiring place and they stripped the head and checked it and fitted my stem seals all the bits were genuine peugeot it never smoked before i stripped it so i am thinking maybe dodgy stem seals
Posted 30th Apr 2012 at 20:13
It's either the wrong seals have been fitted, or one seal hasn't seated properly and it's letting oil into the chamber.
This would make more sense as you stated that sometimes the engine goes down onto 3 cylinders, indicating that 1 cylinder has a fouled plug. Best thing to do, is to go out for a drive and as soon as you come back whip the plugs out and have a check to see what colour they are.
My guess is you will find one plug is all sooted up, and it will be that cylinder that has the valve stem seal issue. Yes
Posted 30th Apr 2012 at 20:25
never heard of 5mm gti6 stem seals, do make sure XU10J4R ones haven't been fitted though, as they are incorrect.
masses of audi and volvo engines use the same seal as a gti6.
depends how long it had gone for, but you could have a knackered bore+rings from the steam washing effect the gasket was doing .
Posted 30th Apr 2012 at 20:35
weemangti
it didnt smoke before i took it apart so must be something i done sould of left the old ones and just done the gasket
Posted 30th Apr 2012 at 21:19
Looks like you are going to have to strip it down again and redo the seals then mate...
Posted 30th Apr 2012 at 22:10
weemangti
UPDATE
The 6 had been starting a bit funny last few days then was driving it earlier come to a set of traffic lights went to stop and it cut out went to start it sounds like it has no compresion then i opened the bonnet it pumped the engine oil out the dip stick tube and out the filler cap. OH s**t !!!!!!Cry
Posted 13th May 2012 at 20:24
fatlapit
Rings it is then
Posted 13th May 2012 at 20:35
weemangti
anyone no of a good engine or engine rebuilder near wiltshire Dunno
Posted 13th May 2012 at 21:50
fatlapit
Rich w mate he just built my forged turbo engine
Posted 13th May 2012 at 22:03
miles at pugracing isn't too far from you and might be able to sort you out.
Posted 13th May 2012 at 22:08
rich_w
It does sound like rings, it's also worth checking the PCV system isn't blocked.
My guess is the coolant getting into the bores has washed the oil off the cylinder walls (similar to bore wash where rich running / excessive fuel washes the oil from the cylinder walls), and has worn the rings and / or bores.
Contact Details:
07732 822546
Posted 14th May 2012 at 10:29
weemangti
i spoke to a bloke called collin from pug performane in hampshire about a second hand engine seemed like a real genuine bloke just wondered anyone delt with them before Crazy
Posted 14th May 2012 at 13:27
Shut up
Posted 14th May 2012 at 13:36
miles is closer to you I do believe Thumbs up
Posted 14th May 2012 at 14:17
swiftyboi006
stan_306gti6 wrote:
Shut up
Laugh my ass off
Black p3 Love
Posted 14th May 2012 at 21:02
fatlapit
i just bought an engine from him too a good mate of mine tho, but saying that the engine got fully rebuilt anyway lol
Posted 14th May 2012 at 21:16
weemangti
i picked the second hand engine up at the weekend finished fitting it today runs sweat as thumbs up to collin at pug performance in hampshire for sorting me out Thumbs up Big grin
Posted 23rd May 2012 at 19:16
Good lad Thumbs up
Ignore the chimps on here most have never had dealings with colin Smile
Posted 23rd May 2012 at 19:21
weemangti
bigbadbowen wrote:
Good lad Thumbs up
top bloke very helpfull would recomend him to anyone Thumbs up
Posted 23rd May 2012 at 19:31
