Author Subject: Knocking noise
Rix13
My 306 has just started to knock on start up and when its turned off, would I be right in suspecting engine mount? noticed that its a bit soft as it is, just been lowered and think it may have finished it off. Want to just make sure before I shell out for a decent set of mounts.
www.eastcoastmodified.org
E46 318i tourer SE - Dog Car/Work horse
306 Gti - Track Project
Posted 4th May 2012 at 18:19
aaron6
Probly a problem with the top engine mount. Whip off the support arm and have a look. Failing that, go to a garage and get it on the ramp and check the others using a pry bar. My guess is the chassis has a crack in it or the driveshaft mount its split.
Posted 4th May 2012 at 18:23
Rix13
by crack in chassis take it you mean the point where the mount screws in?
Posted 4th May 2012 at 18:32
aaron6
Indeed. Its an easy check. I have had this on both my gti6's.
Posted 4th May 2012 at 22:20
Rix13
starting to confuse me this now. took mount off and everything other day and not cracked so happy about that but started to when its running and sat still. cant get it to do it when the engine is off and wont do it when im driving and letting off heavy which would of thought it would. any ideas?
Posted 6th May 2012 at 14:12
aaron6
Check the other mounts, if the chassis wasn't cracked and you tightened enough when re-fitting it, it won't be that mount. Could be either of the other 2 though.
Posted 6th May 2012 at 19:16
