Author Subject: Limp mode on 2.0 hdi
scott-723
Hello iv just got meself a Citroen xsara hdi and it's gone into limp mode. Does anyone no how to bypass it cars working mint. No one can find a fault so I wanna bypass it if I can thanks
Platinum Silver GTI6 DOB friday 22/01/1999
Xbox tag - pugway 306
Posted 5th May 2012 at 03:57
must be a fault or it wouldnt do it
Posted 5th May 2012 at 06:51
tvrfan007
Limp mode will be there because of a reason, you can't just bypass it as it's not doing it just to play havoc with you.
It will most likely be a fuel pressure issue, that's the main culprit for limp home mode. You will probably have a dying lift pump (tank pump), however you should have fault codes - if not then someone has been messing around with your ECU.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 5th May 2012 at 06:53
antcla.85
Boost temp sender? Sometimes on my engines they fail sending the wrong temp signal causing the engine to act as if in limp mode but actually its not boosting. Thats if they have them.
Life is short, make it interesting
Buy a Peugeot!
Posted 5th May 2012 at 07:20
pugjim
You need the fault codes reading by someone who has diagbox/lexia.
Posted 5th May 2012 at 11:02
rob_humphrey
Throttle sensor caused it on mine Thumbs up
Team Moonstone Big grin
Team Working Aircon
Posted 5th May 2012 at 11:30
