Author Subject: No handbrake application ????????
Moonstone6
Hi all my the gti6 I recently brought has had a s**te handbreak so I looked at callipers and noticed one of them does not bite the disc when the lever is pulled the cable is still in one piece and the arm on calliper moves when handbrake pulled but the piston does not move Dunno just to confuse me more it is a nearly new delph calliper new discs and pads with dowel on one to locate in in the groove on piston have I done something stupid or missed something
Cheers lads Dunno
Posted 10th May 2012 at 19:57
are they seized? sliders etc?
did you stomp the pedal with wheels on the ground before fittng handbrake cable?
Posted 10th May 2012 at 19:59
Moonstone6
No mate it slides back n forth as it should my only thinkin is the callipers fooked
Posted 10th May 2012 at 21:16
did you do the second bit mentioned?
Posted 10th May 2012 at 21:19
I reckon it needs bleeding properly ?
Posted 10th May 2012 at 21:25
Moonstone6
I even bled it aswell to cancel that scenario and still the same mateDunno
Posted 10th May 2012 at 22:25
Moonstone6
Never noticed the 2nd bit you put I wound calliper back with handbrake released but cable connected the arm On calliper was in the released position I then pumped the pedal then applied the handbreak to check I think the calliper is faulty its sealed on the back clean grease n rubber boot is perfect
Posted 10th May 2012 at 22:28
Does it have a new cable ? Sounds like the cable is not tensioned correctly ? If it's had a new cable it could be the wrong side ? Ie left on right or vise verser ? One is slightly longer than the other Yes
Posted 10th May 2012 at 22:46
Moonstone6
Oo I never knew that about the cables being diffo lengths well I'm gonna get it on the ramp in the week so il av a better look at it then il strip calliper aswell to have a butchers thanks dude
Posted 10th May 2012 at 23:43
cress87
But you said the lever on the caliper moves when you apply the handbrake so it can't be a cable issue. Dunno
Posted 10th May 2012 at 23:49
Moonstone6
Well that's what I though mate I thought you just adjust the small cable on the lever and the two cables are fixed length I checked the other calliper for comparison n the levers for handbrake cable are in identical positions when h brake applied n released its gotta be a fault within the calliper I'd have a look on my break at work but I'm too busy Wink Tonite
Posted 11th May 2012 at 00:54
From what you've said, I'd be inclined to agree that the caliper is where the fault lies.
If the wheel is off the floor and you turn it by hand, get a mate to press the brake pedal and see if it stops you being able to turn the wheel. That will tell you if the caliper is working at all.
Posted 11th May 2012 at 10:31
if you don't press the pedal several times with the wheels on the ground (or the compensator valve held open) the piston wont self adjust, fitting the cable before doing this seems to prevent it from doing so fully.
also pressing the pedal with the wheel off the floor with a load compensator doesn't always work Wink
Posted 11th May 2012 at 10:57
Doesn't mean its moving far enough thoughWink
Lever the handbrake arm on the caliper with a screwdriver,and see if you can turn the wheel thenThumbs up
I had a caliper that was like this on my 309,lever moved fully on but did nothing to the pistonNo
Posted 11th May 2012 at 11:21
Moonstone6
Hi mate yea the calliper works fine hydraulically just not mechanically the disc was new last month and had even wear to the other one Dunno Gotta. Be the calliper
Posted 11th May 2012 at 13:53
As Coskev says try to manually pull the handbrake lever on the caliper on with a screwdriver and see if the wheel locks up. Yes
Posted 11th May 2012 at 14:01
Moonstone6
Yep it's the only thing for it ent it lads thanks for your input fellas Thumbs up
Posted 11th May 2012 at 14:27
ian7675
Techno Viking
How many clicks on the handbrake lever have you adjusted it to?
Less than 24 hours to go!
Posted 11th May 2012 at 14:32
An acceptable tolerance is between 4 and 7 clicks by the way...
Seeing as the handbrakes aren't the best on the disc beam I usually set mine to 4. Yes
Posted 11th May 2012 at 15:33
ian7675
Techno Viking
I know Stan, I did 4 too. I was asking the OP to check the cable isn't too slack on the lever Thumbs up
Posted 11th May 2012 at 16:31
