displaying posts 26 to 35 of 35
Pages (2): 1 [2]
Author Subject: A few pictures of the bodies...
pete_rallye
Yeah, those 2 connections go into a common space anyway inside the cam cover so the block breather is effectively breathing to outside anyway.
Lap of the 'ring
Posted 13th May 2012 at 22:40
miles
Very odd, But the cam cover breathers should be a standard or oil will get around the bay as you have noticed, There is also a T connector for the head breather on the block which I guess might be left open, Not good as you never know what may fall inside.
Worth fitting a catch tank or a oil breather on the end of a pipe under the car or you might start smelling oil vapour inside the cabin, which isn't the best,
The bolt blocks the old vacume from the inlet manifold, Much easier to fit a new section of pipe between the pump and metal pipe, also remove's the plastic T piece which can break too.
www.pugracing.com
Posted 13th May 2012 at 23:23
rich306.
Good stuff Smile cheers for that Thumbs up
Ex Bianca 6 Owner R.I.P
Mazda RX7 FD3s - Daily...
Posted 13th May 2012 at 23:24
miles
Plus the Omex run's all by itself, the old ECU and loom should be removed as it's no use at all, Plus without it there makes any fault finding very easy, I know from seeing a well know company in Hampshire wiring, they keep the std loom in place in a 205 which makes it a nightmare, also looks untidy too
www.pugracing.com
Posted 13th May 2012 at 23:26
atterz
So... is it better to have long runners on the inlet manifold or long trumpets for a better spread of torque? Curious as obviously both wont fit at the same time!
owain wrote:
Posted 13th May 2012 at 23:27
pete_rallye
Generally most tuners say it doesn't make much difference how the 'length' is made up, although position of the butterfly and injectors in relation to the valves can also affect the engines characteristics... The only way to know for sure would be to spend a lot of time and money on the dyno with different bodies/inlets/trumpets.
Lap of the 'ring
Posted 14th May 2012 at 00:18
or speak to an engine builder that has done the calculations and testing Wink
Posted 14th May 2012 at 05:28
matt evans
Looks good Rich, saw you Saturday afternoon Bwaarping your way past Corbett Hospital towards the ring road, i waved but was in a Prius.... so you ignored me LOL!!!!
honestly3k wrote:
owain wrote:
Posted 14th May 2012 at 09:03
Looking good. Can't wait to get mine fitted.
Need to speak to Sandy about mapping it. I like the way he and Colin have designed and engineered everything to get the best out of them for the '6 engine. I was reading up on how the manifold and trumpets they supply were tested and tested until it was right.
  • Posted 14th May 2012 at 10:17
    rich306.
    Post #35
    LOL Sorry about that mate I didn't see you... Don't take it personally to the fact you were in a Prius Razz
    Posted 14th May 2012 at 11:38
    Pages (2): 1 [2]
