Author Subject: Fuel pressure regulator question?
Hi folks, ive noticed my fuel pressure regulator making a hissing noise when I put the ignition on.
Is this normal for my or any other setup?
Thanks andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th May 2012 at 23:34
that'll be the excess fuel returning to the fuel tank.
Posted 17th May 2012 at 23:42
Sounds like air coming out or going in or air somewhere LOL
Posted 17th May 2012 at 23:44
It's so long since mine has run I can't remember if this happens to it or not. LOL
From memory, I haven't noticed anything untoward although like I say, I haven't used it for a while.
Posted 18th May 2012 at 06:28
not surprised with your exhaust stan LOL
wouldn't be able to hear myself think!
Posted 18th May 2012 at 09:03
It can online heard when the ignition is turned on and the fuel pump primes up, it wouldn't be gear able with the engine running due to exhaust.
Posted 18th May 2012 at 11:32
LOL
I can't hear anything at all really when the engine is running, but I haven't noticed this hissing with the ignition switched on either. No
Posted 18th May 2012 at 12:24
Might be that Buzz's pump is on permanently with ignition feed rather than simply primes when turned to pos2.
Posted 18th May 2012 at 12:45
Possible, mine only works on Pos 2, although things like the AFR gauge work on Pos 1. Yes
Posted 18th May 2012 at 14:15
No I think mine primes at position 2, that's what I ment when I put ignition on, I thunk
Posted 18th May 2012 at 15:42
That is what is supposed to happen Andy. Yes
Posted 19th May 2012 at 07:54
It's not the priming noise that I was wOndering about, it was the hissing/air sound from the regulator that I'd never noticed before
Posted 19th May 2012 at 14:52
Have you made sure the retaining clip on it is tight?
Posted 19th May 2012 at 18:57
the spring surclip type thing?
It's either on or off isn't it that thing?
It's probably normal and just something I just noticed
Posted 20th May 2012 at 10:54
as I said before, its perfectly normal.
Posted 20th May 2012 at 11:42
Yeah, that's the thing I mean...Yes
Generally, it is an "on/off" thing, if you leave it off and prime the car, it generally fires out the fuel rail at high speed. Shock
I have never noticed this "hissing of air" before with mine, although maybe it is there and I've just not registered it. Can you hear it when you're in the car with the bonnet shut, or is it only apparant when you're under the bonnet and the ignition is turned to pos 2? Dunno
Posted 20th May 2012 at 13:26
It's heard inside the car with the bonnet closed when you turn the ignition to no2, it lasts a few seconds and then stops.
Posted 20th May 2012 at 19:29
Going by that description then, I've never heard anything like that coming from mine...
Maybe you ought to ask Rich what he thinks as mine definitely doesn't do this. No
Posted 20th May 2012 at 19:44
yeah Ill mention it to him when I see him, he's gonna think I'm a right hypochondriac LOL
Posted 21st May 2012 at 11:43
You are the new "justinaccurate". Laugh my ass off
Posted 21st May 2012 at 11:46
LOL
Posted 21st May 2012 at 11:52
My exhaust sounds different aswell, it sounds
Like its blowing but it's from the end of the tailpipe not further up the system.
Posted 21st May 2012 at 11:54
That's weird as surely it must be difficult to tell if it's blowing from a place where the gases are supposed to be exiting? Dunno
Posted 21st May 2012 at 12:12
