Author Subject: Window falls down - whats wrong?
sergioiacobucci
Hi,
My driver side window falls down. So if I put it down the front that is closest to the wing mirror falls down - does anyone know what it could be?
Cheers Smile
Phase 1 silver track car
335i daily
Posted 25th May 2012 at 00:25
6waysforward
The window has come out of the runners by the sounds of it prob due to a knackered clip or the runner at the front has come away.
Posted 25th May 2012 at 00:27
sergioiacobucci
Ok cool take the door card off and have a look? Or will it be covered so i cannot see it?
Thanks for the pointers
335i daily
Posted 25th May 2012 at 00:31
pebbles167
Take the door card off and peel back the foam, power down the window until you can access the window + clip and inspect.
Post up here when you can see what's wrong and ill take you from there. Thumbs up
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 25th May 2012 at 00:47
sergioiacobucci
Great thanks Big grin will do that tomorrow morning and post it up
cheers for the help guys
335i daily
Posted 25th May 2012 at 00:48
woody.
Be careful if you're buying a second hand motor unit, they fit different in phase 1's than phase 2/3's. I had to chop some bolts up to fit them and they use a different rubber part to hold the window on the main slider.
It sounds like the clip on the side of the window nearest the B-pillar has broken. These can be had from pug for a quid or two.
This job really got on my tits when my drivers side one went bad. Thinking back it's so easy to fix, just had the wrong parts! Good luck
Posted 25th May 2012 at 02:14
webster
The job is a pain in the ass and fiddly so take your time and be ready to become frustrated Smile
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 25th May 2012 at 07:38
The clip will undoubtedley let go again (I had a garage refit the window twice for it to fail again within a few weeks), I lubed the runners with silicone grease and then used a dremmel to key up the surface of the glass on both sides in the area the clip fits onto the window, I then put epoxy resin on the glass and the clip and left the two to cure for half an hour before refitting. It never came off again after that.
Posted 25th May 2012 at 09:33
willow
Yes, as above a few years ago my wife's dturbo had this problem, tried several clips and I ended up changing the whole window regulator mechanism. It just popped out again. Turns out all it needed was a good spray of silicone around the seals and it was fine after that.
Posted 25th May 2012 at 12:48
ardandy
It should be up?
Posted 25th May 2012 at 15:30
