Came out nice and easy. Will now be split - gearbox was fine so that will be up for sale soon, same with the bottom end......head needs to be checked for any damage and then will base what I do with it on that.
| Author | Subject: A sad day |
gota6again
Seasoned Pro Location: Gone Registered: 18 Jan 2009 Posts: 1,595 Status: Offline |
Finally the day came when X132FVC's heart was ripped out from her ![]() ![]() ![]() ![]() Came out nice and easy. Will now be split - gearbox was fine so that will be up for sale soon, same with the bottom end......head needs to be checked for any damage and then will base what I do with it on that. |
Christmas was 5 months ago and you still have your Xmas tree outside?Pie key! ![]() ________________________________________ ![]() |
gota6again
dangti6 wrote: Christmas was 5 months ago and you still have your Xmas tree outside? Pie key! ![]() It's a science experiment |
dangti6 wrote: Christmas was 5 months ago and you still have your Xmas tree outside? Pie key! ![]() The breaking thread started 10 months ago and the engine has only just come out. Not sure what`s worse... ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
gota6again
thugpuggin wrote: dangti6 wrote: Christmas was 5 months ago and you still have your Xmas tree outside? Pie key! ![]() The breaking thread started 10 months ago and the engine has only just come out. Not sure what`s worse... I know, I'm not a full time car breaker so most it was done to order if you like. After a year of it just sitting around and only being looked at when a part was need I've decided to strip it all and get rid of the shell and get the drive back. |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
I remember seeing this down the A30 once, RIP |
stan_306gti6
Why the breaking? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
gota6again
stan_306gti6 wrote: Why the breaking? ![]() Headgasket started going and after throwing shed loads of money at it I just had enough |
stan_306gti6
Surely would have only cost £600 max to get it done? ![]() Could even have done it in stages to keep the cost reasonable? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
gota6again
After throwing about £2k at it doing various bits and then losing weekends under it I thought best to move on, would love another one oneday. |
stan_306gti6
gota6again wrote: After throwing about £2k at it doing various bits and then losing weekends under it I thought best to move on, would love another one oneday. Fair enough I guess, hopefully you'll be back in the fold some day. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Rich E
If it's sat for 10 months after HG failure then you may find one (or more) of the bores are rusted beyond recovery. Just depends on how much coolant has been sat in the bores.________________________________________ Rich |
gota6again
Thanks for the heads up Rich, didn't think of that but only because I took it off the road as soon as the first sign of a failing HG showed up. If there had been coolent in the bores, will the rust be obvious - never taken an engine apart so not sure what to expect. |
stan_306gti6
gota6again wrote: If there had been coolent in the bores, will the rust be obvious - never taken an engine apart so not sure what to expect. Yes, it will be fairly obvious and a good heads up from Rich about this issue. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
720puggti
Seasoned Pro Location: West London Registered: 18 Jan 2009 Posts: 1,069 Status: Offline |
Finally Dee! Although it's a sad thing to see another 6 being broken up, but it needed to be done. Perhaps now someone can benefit from the cylinder head ![]() ________________________________________ Deepak Gohil |
woody.
You little vulture deepak! |
