Author Subject: help needed asap please (engine)
sheldon0160
hi everyone i know this is probably in the wrong section but i really need help i have a 1997 gti6 and for past couple days sometimes it wont start it turns over but jus dont fire up but if you disconect the battery and put it back on it starts up bt sometimes cuts out while driving but starts up again.i can sometimes drive it for like hour no problems do some shopping and come back and it wont start n some times it will what could it be. it started really after i got the car washed in a car wash
any help appreciated thankyou
s.coles
Posted 4th Jun 2012 at 00:47
yippeekayay
Are you sure the terminals on the battery are tight. Make sure they dont turn on the battery poles at all. Also make sure the earth is good. Maybe run a jump lead to the chassis when it wont start and see if it cures the issue.
x box "yippeekayaymofo"
Posted 4th Jun 2012 at 01:12
could try Vaseline petroleum jelly smeared around the battery terminals to help conduct a little better
also a good wire brush may help too Dunno
Posted 4th Jun 2012 at 02:03
This was my first thought. Yes
I am suspecting a dodgy Earth if it turns over but won't fire. There are a few to check, start with the battery negative terminal, then there are a couple on top of the gearbox and one on the passenger side inner chassis front leg.
It is worthwhile disconnecting all of these, cleaning them up and the mating area on which they sit and then retightening them all down. Give that a try and see how you get on first. Smile
Posted 4th Jun 2012 at 09:26
sheldon0160
hi terminals are fine done them all and still same problem hen its turning over and dont start u cant hear the fuel pump prime. someone said could b crank sensor?
s.coles
Posted 4th Jun 2012 at 17:16
Could be crank sensor although they usually do or don't work ?
Icv could be at fault ? Tried taking it off and cleaning it ?
Posted 4th Jun 2012 at 17:55
Bad Earth, crank sensor or possibly fuel cut off switch...
Check the plug on the fuel cut off switch, make sure it is in there tight, and not loose only just about making a connection. Wink
Posted 4th Jun 2012 at 18:49
sheldon0160
heres the icv
s.coles
Posted 4th Jun 2012 at 19:19
sheldon0160
it ok cleaned it still the same. once battery is disconnected n put back on dont it reset the ecu
s.coles
Posted 4th Jun 2012 at 19:22
It is supposed to, it is believed you need the battery disconnected for around 10 minutes to achieve this. Yes
Posted 4th Jun 2012 at 19:37
sheldon0160
oh i disconnect it for like 10 sec n put it bk on n it starts lol becomin a real pain in the ass lol
s.coles
Posted 4th Jun 2012 at 19:43
