Author Subject: aux belt pulleys qty ?
skybluken
i have a ph1 no a/c and trying to fit a 6pk1160 belt TO LONG!!. I have 4 pulleys? (PAS pump,crank,tensioner and alternator) the tensioner is manual at the top behind pas pump, all pictures i have found seem to show one at the bottom aswell? between crank and alternator below tensioner do i need this or can i just mis this out and put a shorter belt on. Car was originally throwing belts then i discovered i had no spacers on pas pump so was out so now have spare one lol.
Diablo Phase 1 NOW DEAD
Alfa 156 2.0 JTS
Posted 5th Jun 2012 at 12:40
1163mm is the correct length of the belt you need for that setup. Yes
I believe you should only have 4 pulleys for it to travel round...
Posted 5th Jun 2012 at 12:53
skybluken
i must be gettin the route wrong cos its to long anyone got a picture or draw one to show how it should fit please
Alfa 156 2.0 JTS
Posted 5th Jun 2012 at 13:04
ryangti6
This is how it should be
Ryan
Posted 5th Jun 2012 at 13:20
There is a bolt missing out of that tensioner Ryan...
Posted 5th Jun 2012 at 13:30
ryangti6
Well done for pointing out the obvious Stan Roll eyes
I think that picture is still of more use than telling the guy he should only have 4 pullies when clearly he should have 5...
Ryan
Posted 5th Jun 2012 at 14:06
skybluken
cheers ryangti6.guess i got to source a replacement pulley?
Alfa 156 2.0 JTS
Posted 5th Jun 2012 at 14:21
I was pointing it out in case the OP did not notice and was unsure why his setup looked different to the one pictured when he went back to have another go at fitting...no need for the attitude. No No
Yes, that picture is extremely helpful, well done for posting it up. Thumbs up
I obviously made a mistake when I was trying to picture the setup in my head, again a simple mistake no need to cause an issue. Smile
Posted 5th Jun 2012 at 17:47
mechanical_repairs
Ha ha told you Stan you thicko.
Carl
Posted 5th Jun 2012 at 19:16
Laugh @ Carl!
Posted 5th Jun 2012 at 19:18
ryangti6
Well perhaps if it wasn't aimed at me, didn't have the ... you seem to post after everything and in general didn't post a lot of comments stating the obvious, I wouldn't of said anything. Nothing in my post was offensive so you can save the lecture on the attitude thanks. Thumbs up
Ryan
Posted 5th Jun 2012 at 20:34
woody.
:popcornsmiley Yes
Posted 6th Jun 2012 at 01:22
Ah bugger, I have one from GSF which says "6PK 1155" - does that mean they've given me the wrong one? I'm also P1 without air con.
Posted 6th Jun 2012 at 08:10
skybluken
Guees so, Peugeot told me it was 6 rib 1160 then wanted £18+ vat, GSF i went lol. Now i need a pulley cos thats to long :-( more ruddy money
Alfa 156 2.0 JTS
Posted 6th Jun 2012 at 09:20
Annoying, guess I'm off to GSF today then.
Posted 6th Jun 2012 at 09:24
skybluken
Had to have a 6pk 1165 as they didnt have a 1160 cost me £10. Then got home to fit the pas pump as had to get new spacers and bolts(£17 @ peugeot :-() as the twat who put the replacement engine in didnt know hs bolts from his nuts. Then discovered belt to long because i got a pulley missing aswell :@
Alfa 156 2.0 JTS
Posted 6th Jun 2012 at 09:34
I'd hold fire before you start worrying. Stan isn't on top form today so I would take his length with a pinch of salt.
Cry
  • Posted 6th Jun 2012 at 09:38
    1163mm it is. Yes
    Posted 6th Jun 2012 at 10:22
    allesclar
    just a quick one, how does one get the two middle pulleys off? i cant see the bolt in the picture.
    Team allesclar ®
    Posted 17th Jun 2012 at 15:30
    skybluken
    The tensioner has 2 bolts the bottom one it pivots on and the top one is the locking one. The idle pulley just has 2 bolts one top and one bottom these are lots of fun as hard to get at but all are 13mm, remove wheel and inned trim to get at bottom bolt, have fun
    Alfa 156 2.0 JTS
    Posted 17th Jun 2012 at 15:44
