Author Subject: Cam cover gaskets ??
Moonstone6
Hi folks are the rocker cover gaskets for our engines (XU10J4RS) available from pug or are they just a sealant ? I am changing my cam covers for some I have had powdercoated ??????
Cheers lads
Posted 10th Jun 2012 at 21:29
simonjames
Sealant is all thats available
MY EBAY ITEMS
07943066306
Posted 10th Jun 2012 at 22:21
The gaskets are bonded onto the covers,they are not available on there ownThumbs down
Its a right job to get the covers sealed if you have removed the seals alltogetherYes
Posted 10th Jun 2012 at 22:23
Good luck getting them sealed
Posted 10th Jun 2012 at 22:30
barnettjd77
When i asked my pug dealer this they said it was a straight bare fit... thick fu**ers!!LOL
The 5th attempt i got mine sealed.
A red rallye in progress!
Posted 11th Jun 2012 at 00:10
I once discussed this with Pugjim,..
Could a cast of the bottom of the cam covers Be made and
Then make a gasket that would fit perfectly?
Posted 11th Jun 2012 at 01:12
Moonstone6
Yea I can believe that mate they haven't got a clue about the real peugeots the just monkeys ain't they lol
Posted 11th Jun 2012 at 06:58
Moonstone6
Cheers mate ok il try some rtv sealent on them that's all it looks like anyway it's as if they apply a bead to the cam covers and allow it to cure slightly before fitting them Dunno
Posted 11th Jun 2012 at 07:01
The problem is the size of the gap you need to fillYes
The cam covers do not go right down flat onto the cam carriersWink
If you look at the part where the bolts go threw the cover they are lower than the outer surface where gasket sits,to stop the gaskets getting squashed too much by heavy handed monkeys,so you need a massive bead of sealant,which is hard to get rightThumbs down
Bolt one of your new covers on to give you some idea of how thick a bead of sealer you needThumbs up
Posted 11th Jun 2012 at 09:16
