Author Subject: Can somebody have a look over my GTI6?
JimmyRiddle
Hey,
I've a Phase 2 GTI6 and it's had a power loss problem on it for over 18 months. The power dips in and out, so it runs as sweet as a nut or as flat as a pancake but for a majority of the time it's flat.
I've tried to fix it with a change of the following -
- Lambda sensor
- MAP sensor
- Fuel Filter/pump
- Exhaust and CAT
- Plugs
- Air Filter
- Reset ECU
- I've also checked the coil packs and they're okay.
All of the above needed doing at some point anyway but I thought it was best just to see if it made a difference.
Anyhow, it's not got to the root of the problem and I'm left head scratching.
If anyone could have a look over it for me and maybe suggest something new I'd appreciate it. Also, I willing to fork out if you think you could fix it.
I live in the Bristol area but could travel if need be.
Cheers.
James.
Posted 15th Jun 2012 at 14:20
smegal
It sounds like lambda, if you've changed that I'd say check the green coolant temp sensor.
Ex SC-6
Now in a Megane R26
Posted 15th Jun 2012 at 14:30
Mine was a bit funky until after I changed the green sensor previously
Posted 15th Jun 2012 at 14:36
mattgti6phase2
Another one for Ecu temp sensor.
Unplug it when it's running rough and if it makes no difference that's the problem Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 15th Jun 2012 at 14:45
After I have my suspension sorted Im intending on a new radiator but after that im definelty going to replace all of the s**tty french sensors on the car Smile I think it will run a lot nicer then
Posted 15th Jun 2012 at 14:59
JimmyRiddle
Okay, cheers guys. I'll replace it and see what happens.
Posted 15th Jun 2012 at 17:43
Power steering sensor as well Thumbs up
Posted 15th Jun 2012 at 17:44
anth
^yeah thats a good shout, unplug it for a start see it resolves the problem. behind the radiator atatched to the pas pipe.
Posted 15th Jun 2012 at 17:47
I've got a spare green sensor you could try only in Horfield.
Posted 15th Jun 2012 at 17:57
grumpychef
The Rib Man
you haven't got a spare gear-knob have you? Whistle
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 17th Jun 2012 at 22:59
